Question about GE Monogram ZV1050SFSS 42" Island Chimney Hood
The wiring from the fan on my cooker hood has no earth is this ok
I got a cooker hood on ebay when I came to fot I see that the wire from the fan has no earth is this normal. the wiring looks original and I have no reason to think any rewirw has happened
    Sergeant:
    Champion:
  • 205 Answers
Yes mam earthing is must and should be provided because of safety for the equipment and the operator,
Posted on Oct 06, 2009
Testimonial: "yes ok"
EFC90950x lights are not working. Fans are ok. Bulbs changed but lights still not working. Is there a hidden fuse that needs changing?
I have repaired a similar vent hood with this problem. If you have two lamps that are 35 Watts each, order from ebay or Amazon one of the HATCH LIGHTING 80WATT Electronic Transformers. CAT # RS12-80M, 120 Volt. It will cost you about $22 and you use some wire nuts and wire cutters to install it. Please turn off power to the vent hood first!
Nov 02, 2013 | Electrolux Kitchen Ranges
Fan on cooker hood does not work but light works
It it new? Maybe the fan connection in the connection panel come loose or was not done properly from factory. Turn off the breaker to the hood and inspect the wires and connections, if all is good, then maybe the switch needs replacing. Good Luck!
Jun 25, 2012 | Kuppersbusch Designer Island Canopy Cooker...
Dww061350b
if both fan and light have quit working then you have an electrical supply problem. start with checking for thrown breakers in the breaker panel. if none are tripped then you have a broken wire or a wire no longer making a good connection. try twisting the wire nuts tighter were it wires in above it
Jun 02, 2012 | Kuppersbusch Kitchen Ranges
How do l connect my hob cooker to the electrics l have live earth and neutral and on the hob l have earth live 1 and live 2 and no neuatral regards
Hi .. you should check the breaker supplyingh the power vto this cooker. If you find a two pole breaker , then that white wire is power , not a neutral. In this case just treat the two wires you have as both hot and connect each to a wire on the cooker.
Apr 07, 2010 | AT&T Siemens S46 GSM Cellular Phone
I need to wire up an electric cooker ,am unsure what wires go where as in live earth etc
White is neutral, green (or bare copper) is ground (earth), black is hot. If it's a 220-volt unit you will also have a red - it's another hot.
Nov 20, 2009 | Ovens
New element does not have an eartjh attachment.
I fixed a bolt to the frame and crimped the earth to a ring terminal and attached it to the bolt.
Apr 18, 2009 | Kitchen Ranges
Wiring problem
Yes just like damic says,
But dont forget to add a fused switch one as well.
You'll be glad you did.
What i did was..from the hood, i did a channel into the wall (with plastic conduit).. to go left then followed it down to make it flush.
(so i could put the cupboard back on)
Plastered then tiled up the area as well as added the extra plug.
It'll run sraight off the mains.
Apr 11, 2009 | Baumatic F60 Stainless Steel Kitchen Hood
BABT83.2AL Canopy Rangehood The fan/suction is not working. A slight straining noise is heard. The light is working as is the display panel.
These units have a history of fan failure due to inferior 220 volt Italian fan.
I have just had fan fail and retrofitted a ebmpapst blower fan model D2E146HT6702 which is readily available in Aus for around $120.
The fan speed control is by inverter variable output so you don't use all the speed select wires that this fan has. Connect the Red wire on the range hood to the Black on the motor (High speed winding) and the Black on the range hood to the Blue on the motor (Neutral) and the earth to the earth (Green).
Disconnect and toss the cap in the white enclosure under the PC board enclosure (the new fan has the cap on board). Don't know how easy to fit in the range hood as mine is in an acoustic fan housing in the roof (makes it wisper quiet when running)
Apr 07, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Cooker hood not working
Check power from the wall.
Check power in the wiring coming into the hood.
Check to see wiring is not broken.
Feb 18, 2008 | Kitchen Ranges
GE Monogram ZV1050SFSS 42" Island Chimney Hood Logo
483 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
