Question about Bose Lifestyle 38 System
Sound problems I have sound when I play DVDs or CDs, but not when playing from AUX, or TV. The connections are tight, no mute buttons are pressed, and the sound was working earlier.
  • 1 more comment
  • havlickjo Dec 24, 2007
    Great. The solutio nworked perfectly. I had to unplug the unit, and when I pluged it back in everything worked greta. Thank you for the easy accurate answer.
  • Anonymous Dec 24, 2007
    CD and DVD works, stored music works no sound through televesion and cable television. Checked all wiring looks fine no mute buttons on.
  • Anonymous Nov 13, 2008
    I just ran into the same problem. After trying everything under the sun to solve it, I found this website posting. After unplugging the media center and plugging it back in, everything works fine! It goes to show - always start with the simple things first!
  • 14 Answers
Power down the media center for 20 seconds then power it back up. This will clear the problem.
Posted on Dec 24, 2007
Why did my sound just quit?
Try turning off the device then unplug it then hold the power button in for 10 seconds then plug it in and restart it as a possibility
May 30, 2014 | Haier LEC24B1380 24 inch LED HDTV/DVD...
No sound from pre-recorded dvds in tv/dvd combo
Check the sound setup to TV. Refer its user manual for details. Check whether the audio format to the recorded disc do match with to that of TVs.
Apr 25, 2013 | Televison & Video
No sound on tv but when i play dvds i have sound
Connect the input device to some other TV and check. Look for: child lock, selective mute button, basic TV volume too low etc.
Jul 19, 2012 | Zenith Televison & Video
Why? no sound from the speskers at all.
There are a few things that could cause no sound and although some are obvious I'll got through them all..
1) Sound is on Minimum
2) Sound is Muted
3) No Power to Subwoofer
4) Speakers connected Incorrectly or Faulty
5) No AUDIO IN connections to TV-IN or AUX-IN
6) Incorrect Input Source is Selected (See Below)
Connecting audio from TV
When connecting the audio output from your TV to this Home Theater Audio System, you will have the sound of the
TV output on all the speakers. It will enable you to enjoy the multi-channel surround sound capabilities.
Use an audio cable (red/white - not supplied) to connect the TV IN jacks on this DVD system to the AUDIO OUT
jacks on the TV. To listen to the sound, press TV on the remote control as the sound source that you want to play.
Connecting audio from an audio/video device
This DVD system provides analog and digital audio connection. You can connect the audio output from an
audio/video device (e.g. VCR, Cable/Satellite Box) to this Home Theater Audio System in order to enjoy the
Use an audio cable (red/white - not supplied) to connect the AUX IN jacks on this DVD system to the AUDIO OUT
jacks on the connected device. To listen to the sound, press AUX/DI to select "AUX" as the sound source that
you want to play.
Or
Use a coaxial cable (not supplied) to connect the DIGITAL IN jack on this DVD system to the DIGITAL OUT jack on
the connected device. To listen to the sound, press AUX/DI to select "DI" as the sound source that you want to play.
Please leave feedback
Cheers
Andy
Apr 27, 2011 | Philips HTS3450 System
Will play dvds with sound fine...but no sound from tv
You have to connect extra red & white audio cable from your TV's (or cable box, if you have one) AUDIO OUT to the Home Theater's AUX IN 2 at the back (below Video In). Set the HTS unit to AUX 2 using the AUX button on the remote control and you should be able to get sound.
Jun 14, 2009 | Samsung HT-P38 System
I can hear cds and see video on my hp dvd 1040i multiformat dvd writer but I can not hear audio to the movie/dvds i have rented.
Sounds like you might have a setting that is incorrect for DVDs in the setup menu.
Grab your DVD player remote and press the SETUP button. Navigate to the audio menu. Make sure Spdif is turned off (unless you're using an optical cable for your sound), that the audio stream is set to PCM (standard for CDs) or RAW, and turn off any Dolby/Digital Dolby/Surround Sound/etc. Now play a disc.
There's also another way if your remote has an AUDIO button. While the DVD is playing, press the AUDIO button and you should see a small windo that pops up that will tell you what the audio is set to. Press the button and wait a couple of seconds between presses to see if the audio starts playing.
May 12, 2008 | Televison & Video
How to get sound through speakers with tv and not just dvds
Just wire your TV audio out to one of the receivers (DVD player) audio in and select AUX when you want the TV sound to play through the surround sound. You also might want to turn the volume down or off on your TV to get the full surround sound feeling, but that's your call.
Jan 06, 2008 | NexxTech ESDVD100 System
Hitachi screen goes snowy and sound is totally distorted
Sounds like bad solder connect in tv tuner....can usually be
repaired or replaced.......................T.
Nov 30, 2007 | Hitachi 43FDX01B TV
CD player that doesn't play
I had the same problem.
I cut the orange wire which went into the black connecter block
and WOW I had sound...
brilliant
thanks a lot
Andy - North Yorkshire, England
Oct 11, 2007 | Panasonic CQ-C1303U CD Player
Only backround sounds play, no talking
find the info/display key on the remote and press it,go down to the box that show head speckers it should show 2 ENG and CH2.
if not change it by pressing the down key then press ok key
Apr 22, 2007 | Zenith DVT412 System
Bose Lifestyle 38 System Logo
206 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
