Cartridge jammed It wont print - telling me that the "cartridge is jammed" Please Help! The sound the printer is making doesn't sound right either
  • millerbarr Oct 06, 2009
    Yes, I've taken them out and put them back again, but it still says that the cartridge is jammed
  • Vladimir Zavodny
    Vladimir Zavodny May 11, 2010
    Have you tried taking them all out and putting them back again?
  • 76 Answers
Check cartrige. If cartrige does not make right contact or its not original,thats the problem.
Posted on Oct 06, 2009
Testimonial: "THANKYOU! I've changed the cartridges and it worked! "
Right catridge not correct
Make sure you are inserting the correct cartridge versions for your Lexmark X5470 printer. Color cartridges compatible for your model are #33 and #35.
Try to re-insert the right cartridge into the printer. If that doesn't help, remove the right cartridge from your printer again. Close the printer cover. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds. When the printer turns on, re-insert your right cartridge. Close the printer cover and check for any errors. Try to print a document to verify that the problem is fixed.
If the problem continues, try to do the Clean Cartridge function from the printer operator panel. On Copy mode, press the Menu button > select Tools > select Maintenance > select Clean Cartridges. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Try to print a document to verify that the problem is fixed.
If the error still appears on the display screen, you probably have a faulty cartridge. Please replace it with a new genuine Lexmark cartridge.
Sep 21, 2011 | Lexmark X5470 All-In-One InkJet Printer
Copier makes a noise when first turned on and then it tells me to open the door clear carriage jam and press enter. But that does not work. The printer has been sitting for a little...
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Nov 29, 2010 | HP PSC 1600 InkJet Printer
Errror e flashing. i cant see any paper jam or small object that affect the sensor.please help me
Nov 25, 2010 | Office Equipment & Supplies
Please help, the Power light is blinking green rather that just solid and nothing will print. When I open the cartridge door the ink carriage is in the middle rather that to the right as it usually is....
Sounds like it is trying to tell you to change the ink cartridge as that is where the cartridge parks for changing? My printer blinks green when it needs paper, does yours have paper and is it inserted properly? Have you checked for a paper jam?
The clue will be in the manual's troubleshooting pages.
Modern printers have a chip on the cartridge itself and these can sometimes give wrong information to the printer..
Nov 22, 2009 | Canon BJC 4300 InkJet Printer
My hp deskjet f4140 keeps showing a paper jam and won't print the page I need, there isn't a paper jam.
There is probably a problem with the position of the cartridge carriage. Try reinstalling the cartridge and make sure that the carriage is in the center of the cartridge access area and the center of the cartridge assembly bar. If it is not try moving the cartridge assembly in either direction and restore the printer for printing. Note any sounds as the cartridge attempts to go to its home position. Any grinding noise may indicate that the position of the cartridge needs to be adjusted. Be patient and adjust the cartridge position again until no grinding sounds are heard. It may help to unplug the printer for 30 seconds between adjustments. Good Luck!
Nov 05, 2009 | HP Deskjet F340 All-In-One Printer
Printer wont print
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Aug 26, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Wont read ink cartidrige
first try taking out the cartrage and try uninstalling the printer off your computer then reinstalling it. before putting in your cartrage make sure your computer detects it and your computer should tell you that it detcets no ink then try replacing it. if the problem consists make sure youave the right cartgae for that printer. Then check that nothing (paper, pen, anything) is stuck or jamming the computer blocking the cartage sensors,
Jan 17, 2009 | Epson PictureMate Photo Printer
Cartridge is jammed, Just clicks steady
gse123@bellsouth.net
I also have a problem with my MP390. Working fine one day and the next I get a Cartridge Jam message plus it clicks steady. How Can I release Cartridge since it is all the way to the right and will not respond to anything I do? Thanks
Jul 15, 2008 | Office Equipment & Supplies
Cartridge Jam Error
your printer hardware is having problem please send it for servicing
Apr 02, 2008 | Canon PIXMA MP780 All-In-One InkJet...
71 people viewed this question
k24674
jasbo
jasbo
