Question about Kenmore Refrigerators
I turned off my refrigerator freezer to clean yesterday afternoon now seems to be taking forever for things to freeze again every thing is thawed out.Kenmore Side By Side model # 106.58432700.
catriver
  • 878 Answers
SOURCE: Kenmore 596.75509400 bottom freezer
JH, did you notice if the freezer back panel was full of frost first time it started thawing? If so you may have a defrost problem. I've had 4 of these control boards (jazz boards) fail on this model in the last week. Behind the front grill, there should be a tech sheet that will show you how to run the componet tests at the control board. Part number for the board is 12002339. This board controls compressor, defrost, damper and fans. Catriver.
Posted on Aug 05, 2007
Amigaman
  • 248 Answers
SOURCE: freezer is cold but not freezing
Look for frost on back wall of freezer on bottom half. If present it's not defrosting. Number 1 culprit is a defrost heater gone bad. You will have to remove lower cover in rear of freezer section to expose coils. Unplug unit pror to doing this. The defrost heater is at bottom of these coils. It has wires to both sides of it. You will need to check continuity of heater or remove heater and take to appliance store and have them check it. If it's open replace it. Use a hair dryer to remove frost from coils to restore airflow. If heater is ok, problem could be a bad thermistor or a bad board. Let me know how you make out with heater.
Posted on Oct 06, 2007
SOURCE: Refrigerator freezes up
turn off
take all food out.
open door of freezer.
let all ice melt away.
remove cover over evaporator coil.
turn on.
should hear fan running.
if it doesn't, hot wire it with 110 v.
if fan no works with hotwire, replace fan.
if fan works with hot wire, find evaporator thermostat about 1 inch big
clipped on coil of evaporator.  short out ( put wire connecting its two wires ) .
if fan runs now, replace evaporator thermostat about $ 15
Posted on Oct 23, 2007
SOURCE: Kenmore refrigerator not cooling or freezing
my refrigerator suddenly stop cooling all the fans run normal. It makes a click Noyce.
Posted on Jun 22, 2008
  • 1462 Answers
SOURCE: refrigerators not cold and freezer
defrost system is not working. check defrost heater and thermal fuse. if appliance fitted with electro-mechanical timer then fault probably lies with timer
Posted on Sep 07, 2008
I have a stainless steel top freezer ice make. the freezer seems t somewhat works but my refrigerator stopped getting cold. what should i do?
Check the fan in the refrigerator section, see if it's blowing air.
Next is the thermostat which you've probably already tried changing. Either one of these could have ice buildup making them not work correctly, so take everything out of the unit and use a house fan blowing into the refrigerator section to melt things out for a couple days. A hair dryer used on the areas will speed things up, but there's a risk of shock. Also the fan or thermostat may need to be replaced. (put your food items in another freezer/refrigerator as they will thaw and warm up within the time it will take for you to try to melt the ice out.)
The fact that the freezer is still working means that your compressor is working and the system isn't out of Freon.
Sep 07, 2016 | Stainless Refrigerators
Freezer won't stay cold
What is the model number of your unit?
Feb 10, 2013 | Gladiator Chillerator Top Freezer...
It seem to not be freezing or cooling properly. Freezer is thawed.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 17, 2011 | KitchenAid Superba KSRG25FK Side by Side...
It kept running, clicking to try and shut off but couldn't. Freezer thawed. I shut off for a while, vacuumed coils, turned back on and it ran fine for three days, working perfectly. Next morning repeat...
Refrigerator
heatman101
Dec 21, 2010 | Amana ARB1914C Bottom Freezer Refrigerator
Our model MBF2256HES seemed to have stopped freezing in the bottom. It only seems to be blowing cool air, not freezing air, and all the food thawed out. I do hear a loud humming turn on for about 15...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 19, 2010 | Maytag Refrigerators
Both the freezer and lower section of refrigerator does not get very cold even at the highest settings. The motor seems to be running all the time and is noisy. Yesterday though I noticed it not running...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 31, 2010 | Frigidaire Refrigerators
Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
My express thaw won't turn off
You have a bad main control board problem . Stuff a shelf in the refrigerator section with crumpled up newspaper and leave running ( the ink in the paper absorbes odor . Takes several days to eliminate .
Jul 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer thaws completely then freezes again
Take loock if are dirty those coils and fan on botton or some place on your freezer. Tri cleaning all. Just be carrefuly to no brake those coils ???? Unplog from outlet bifore ??? I hop you gete fix it. I'm not shur, but tri.
Jul 10, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
37 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
