Question about Electrolux Refrigerators
Electrolux fridge freezer trips RCD on door open
On some occasions when I open the fridge door to my new electrolux fridge freezer the RCD in my consumer board trips out. I've checked the plu and socket and that the light bulbs are in ok. Any suggestions?
  • 641 Answers
SOURCE: rcd tripping
Well done ! Thanks for the information.
Posted on Jul 21, 2007
  • 32 Answers
SOURCE: bulbs and bottom pcb blew, replaced but still not working
the start and run capacitors of the compressor can go short circuit and cause a big spike that can blow the bulbs, trip fuse etc. Inspect the capacitors for splits etc, you may well find that the start cap has blown and so there will not be enough current to get the compressor running.
Posted on Mar 19, 2008
SOURCE: Cannot reverse door on Electrolux fridge freezer
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
Posted on May 27, 2008
SOURCE: fridge freezer
there is a fan inside freezer behind back panel. if pipework behind panel is covered with ice, it will prevent air circulation and the fridge is affected first
take back panel off and check for ice build-up and that the fan is working
Posted on Jun 23, 2008
SOURCE: Fridge prolems Electrolux ERE 3500
No it is a power problem.
Posted on Jun 24, 2008
Electrolux door alarm Won't stop. We open door to turn off alarm. Temp seems right but slight condensation at the very top of the fridge. Need to at least disable alarm until I can get a repair.
Check the back wall of the freezer, I would suspect the beginnings of or a full-on defrost failure... If there is frost on the back wall of the freezer it means the evaporator is blocked, disallowing airflow to the fridge compartment... Electrolux Refrigerator Defrost Thermostat 216731001 . If there is no blockage, but temps are still not cold enough, your Frigidaire may be leaking refrigerant...
Jul 03, 2016 | Electrolux ICON Professional E32AR75JPS...
Where is the sensor for the freezer lights. Lights in fridge work but the freezer lights don't on electrolux brand
they are seperate switches and usually have too touch the door open your eyes and look
Mar 22, 2015 | Electrolux Refrigerators
Can I turn off the freezer but not the fridge on my electrolux french door bottom freezer refrigerator
Unfortunately, the lower frizzer is connected straight to the primary engine. It can't be turned off, unless you turn off the whole fridge. I know, it will be smart for Electrolux to allow that option at a consumer's discretion: to be able to turn the bottom fridge on/off.
Aug 09, 2014 | Electrolux Refrigerators
Freezer door of electrlux freezer keeps coming
Try cleaning along seal and seal itself. If it does not work get new seal. The seal do go bad after a while.. If under warranty call dealer you purchased from for them to replace.
Jul 06, 2009 | Freezers
Electrolux Fridge 2 Door, Electronic Panel Problem
there s three plastic boxes the size of three inches long and two inches high there,s a leak there
Apr 04, 2009 | Electrolux Refrigerators
May 26, 2008 | Freezers
Fridge freezer
fully defrost it 48 hrs with the doors open and that can often cure it.
Feb 11, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerators Logo
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
