Question about ViewSonic Precision Pro8100 Projector
Faint Lines on Viewsonic pro8100 projector
It appears that this problem is common for this projector. The problem can be solved by unplugging it each time? Crappy, but for me it's intermittent and frustrating. You can send it back to Viewsonic, but risk getting the same problem in another projector or someother issue more serious? One person suggested a timer that shuts it down fully each night? I will probabaly tray that too. So disappointed.
SOURCE: Viewsonic PJ556d shuts down after 30-60 seconds
My solution sounds dumb, I had the same issue. Took the lamp cover off the bottom. The screws were loose holding in the lamp. Maybe they heat and expand and eventually work their way out and the lamp doesn't make good contact. Just tightened mine up, the unit would power off after 45 minutes prior. Been on now for 5 hours, no trouble.
Posted on Feb 11, 2009
SOURCE: my viewsonic pj400 projector switches itself off
hello
i have the same problem, a clear image, the the projector shuts down, turn the fan on, and "lamp" blinks.
i returned my projector to viewsonic service center, they told me to change the lamp.
the problem is that a lamp is very expensive!
HudgeFR
Posted on Aug 05, 2009
projdoc
  • 2237 Answers
SOURCE: the projector would not shut down...it was not
if the lamp shuts off and the projector still runs, it's a cool down mode, and will shut off when it reaches a low enough temp. if the lamp doesn't shut off and none of the keys work, the keypad may be faulty. or locked. some projectors have a keypad lock feature that makes it so only the remote can be used. check your manual for keypad lock/unlock.
Posted on Aug 10, 2009
projdoc
  • 2237 Answers
SOURCE: viewsonic projector pj501 - Has purple bloch with
2 issues- the light filter on one of the lcd panels is burnt due to excessive dust and heat. and one of the lcd panels is shot. time to replace the entire optical engine, unless you can get the prism assembly. otherwise, replace the projector. if you do, remember to keep it clean.
Posted on Nov 17, 2009
Testimonial: "Thanks for the help. Looks like the trash for this one!"
salt56
  • 373 Answers
SOURCE: I have a Viewsonic PJ558D
You need to reset the lamp timer. This is likely your problem since you changed the lamp.
Turn the projector on. open the menu. Go to advanced. Scroll down to the first option which should be auto source. Make sure this option is checked. While on this option press right once, left twice, right 3 times, then left 4 times. Another menu will appear. Scroll to lamp time and push enter. This will take it back to zero.
Posted on Jun 12, 2011
When I turn on pjd5126(viewsonic projector), vertical regular lines appears on the screen.
1,the interface between the mother board and DMD drive board
2,to clean the the interface with some alcohol
3,securely plugged
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Oct 12, 2013 | Office Equipment & Supplies
Blotches screen
the problem may be from power cord. call a service center for checking the power cord.
May 03, 2013 | ViewSonic PJD6381 PROJ XGA DLP 24001...
My dlp projector appear white dots on screen hou to solve the problem model pj513d
Sounds like pixel failure. You will probably have to replace the DMD chip
Aug 06, 2011 | ViewSonic PJD6221 3D DLP Projector
VIEWSONIC PJD5111 SHOWS VERTICAL LINES
Hi... Projector show vertical lines... Issue in your logic board filter's missing on logic input board check for fail signal on video input logic board,,, check input connector for broken pin inside connector... also check capacitor & resistance arround video logic processor, possibility of over heat conponent
Oct 25, 2010 | ViewSonic PJD5111 Projector
Unit will not turn on at all
if you are not receiving any lights or not powering up at all. I would check the fuse. Typically the fuse is located in the projector near where you plug the power cord. Ck to see if the fuse is good or bad by visual or meter.
Jun 04, 2010 | ViewSonic Precision Pro8100 Projector
When I turn on my ViewSonic Precision 1080P projector on the indicator status light flashes red and sometimes the projector still comes on but currently it is not interfacing with the receiver. I just see...
I found out how to reset the "clean" icon on the status menu and then moved some connecting wires around on my receiver. They were not totally connected. works great now. Thanks
Jan 02, 2010 | ViewSonic Precision Pro8100 Projector
Viewsonic projector pj501 - Has purple bloch with
Nov 17, 2009 | ViewSonic PJ501 Multimedia Projector
Viewsonic Projector Blue Vertical Line
Hi guys
This is a common Mainboard problem on Projectors , unfortunately the Board will either need repairing or replacing.
No shortcutts on this one !
Aug 12, 2007 | ViewSonic PJ551 Multimedia Projector
Convergence error on viewsonic projector PJ820
your gonna need to get a service manual from the manufacturer and do a convergence alighnment with the on board generator. Unless some unknowing hands have been inside the unit.?? Contact them here at this link Good Luck service.us@viewsonic.com
May 07, 2006 | ViewSonic Projector PJ802 Pro Multimedia...
ViewSonic Precision Pro8100 Projector Logo
285 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
