Question about Magic Chef 31100 Gas Kitchen Range
How to remove thermal coupling from oven - Magic Chef 31100 Gas Kitchen Range
My gas oven won't ignite, takes several tries to ignite it.
All gas appliances have a thermal cut out this will shut the gas off if the flame goes out the down side is when the thermal cut out becomes faulty it can shut the gas of when you are using the cooker the only fix is to replace the thermal cut out
Jan 18, 2015 | Kenmore Ovens
Oven keeps blowing thermal fuse
  • Disconnect the oven's power supply by turning off the breaker in your home's service panel.
  • 2 Open the lower oven door. Remove the screw at the bottom of the trip panel on each side of the oven.
  • 3 Pull the trim away from the oven approximately 2 inches, then slide the trim panel down to remove it from the oven.
  • 4 Remove the screws from the bottom sides of the control panel.
  • 5 Pull the control panel out from the bottom, then lift the panel to remove it from the front of the oven.
  • 6 Detach the wire connectors from the control panel by depressing the tab on each connector and removing it from the control panel.
  • 7 Depress the tabs on the thermal fuse wire connectors, then remove the thermal fuse.
  • 8 Attach the wire connectors to the new thermal fuse to install it in the control panel.
  • 9 Reassemble the oven by reversing the steps used to take it apart.
  • 10 Restore power to the oven.
Jan 21, 2014 | managemylife.com
My toaster showing f5 mag temp and it only toast for 6 seconds then stops any ideas???
assuming its been fixed by now.
thermal-couples on mags trigger at 160F i believe.. forces shutdown for safety.
possible causes..several
mag fan working?
EC fan working?
mag cooling fins packed with dust?
wave guides full of crud causing arching?
mag tip burnt?
faulty mag thermal-couple, unlikely
Nov 07, 2012 | TurboChef TORNADO Electric Oven
Oven won't light
ck thermal coupling see if its to far from pilot light or burnt out
Feb 18, 2012 | General Ovens
Where is the thermal fuse located and how do I replace it on Whirlpool double oven GBD307PRS03? Thanks
The thermal fuse is located on the back of the upper oven to get to it to replace it the oven would need to be removed from the cabinet and the back panel removed ( not fun but what must be done) here is a image of what the thermal fuse looks like.
GENE
Oct 15, 2011 | Whirlpool GBD307PDS Electric Double Oven
My gas oven quit working. I hear it click and I smell gas but it never ignites. I hope it is something simple like a thermal couple. Does it have a thermal couple?
if it clicks,AND u smell gas...you may have a faulty burner.the ignitor IS what opens the gas valve...determined by the amount of wattage the ignitor/thermocouple is pulling...some ignitors get weak and need replaced anyway after 6 or 7 years.
Mar 03, 2010 | Ovens
My oven won't heat up properly
wire brush the oven pilot light orifix flame may be lessened due to carbon buildup then when oven lights its convextion pulls the pilot flame away from thermal coupling with shuts off gas (in case wind blows it out, it will STOP the GAS FLOWING. if the pilot full size (near 3/4 inch tall) then just try to position the thermal coupling nearer the flame (not right on it)
Nov 22, 2009 | Ovens
Oven does not work but ignition continuously clicking
The thermal couple on the gas valve is not working, if this oven is old the thermal couple can be replaced independantly of the gas valve,
if is's newer the whole valve assembly must be replaced. if you have never worked on gas appliances call a pro by the way the valves run about $125.00 you might want to consider replacing the appliance
Nov 14, 2009 | Ovens
The Oven won't heat up
the thermal cut off located on the back of the oven has probably tripped,common problem. replace thermal cut off.
Dec 19, 2008 | Whirlpool RBS245PDS Electric Single Oven
Magic Chef 31100 Gas Kitchen Range Logo
384 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
