My Bissell carpet cleaner model #1697-W will not dispense the cleaning solution and will not **** the water back up--also need to know how you get to the belt on the machine?
The drive belt for the pump is located under a cover on the front right side as you look for the front of the machine. Just lift it up and the belt will be obvious. If it is not sucking then make sure that the dirty water tank is empty and that all the filters are clean and the front of the machine is not clogged with fibres, dirt or hair. Also check pre and post motor filters and clean them if required. Then check the mix control is working OK to allow fluid to flow out of the machine and not switched off. Bissell's are simple machines.
Only sprays fluid for a few seconds when first turns on.Belts are new & pump also replaced...
(More)
Only sprays fluid for a few seconds when first turns on.Belts are new & pump also replaced but didn't help. Flow indicator clean & will start but stops when flow stops. After sitting for a short time , machine will sometimes spray for a few seconds again.
I have a Bissel Proheat powersteamer platinum 11 model #1699-P. Spray comes out the hand attachments...
(More)
I have a Bissel Proheat powersteamer platinum 11 model #1699-P. Spray comes out the hand attachments but nothing comes to the floor. Screens are clean. Belt is fine. Any suggestions?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
