Question about Refrigerators
Freezer is at 20 degrees and refridge is at 75
Last night the freezer was frosted up so I unplugged it and now it is at 20 in the freezer and 75 in the fridge. what can i do?
  • sir_sparks_a Oct 06, 2009
    the fan is working
  • 80 Answers
Make sure the fan is working inside...might be why it frosted up to begin with
Posted on Oct 06, 2009
GE Profile freezer won't maintain temperature
clean the dust from underneath and make sure fan in freezer is working.
Feb 06, 2014 | Refrigerators
Have GE profile refrigerator. It is 3 years old.
OK check the Thermistor, the actual temperature sensor element, and or thermostat if it uses a separate feed.
Sep 10, 2011 | GE Refrigerators
Model TFX30PP purchased 9-10 years ago. The refrigerator & freezer are not cold enough. There was frost built up in the back of the freezer. We defrosted it. Plugged it back in - fridge read in the...
What you have is either a bad heater or heater bi-metal thermostat most likely. I say that since the ice box is working correctly until that frost builds up. Have you checked them. Your heater should test good for continuity(not open or bad) but the bi-metal is a different story. It is open at 50 degrees f and it only closes or carrys voltage when it is sitting in a freezer at 25f. What it does is allow power to the heater when the timer or automatic control calls for defrost. The defrost cycle is around 20 to 40 minutes and power is constantly being sent to that heater the whole time. When it gets warm enough for frost to melt 50F then that bi-metal opens up and kills the power to that heater. If that heater was to stay on it would not be purty. For the rest of the defrost cycle the coils simply rest and drip.
Jun 09, 2010 | Refrigerators
Frigidaire White 16.5 cu. ft. Top Freezer Refrigerator (FRT17HB3)- The freezer works, the refridge portion is warm, it started last week ans seemed intermitten, we turned the cooling higher and it was fine...
All of your cooling coils on this model are located in the freezer. If you are cold enough in the freezer your problem is air flow to the fresh food section.
- There is fan behind the back wall of the freezer, be sure that is running.
- Look for frost build up on the back wall of the freezer, if present we have a defrost problem
- look for the duct or channels between the floor and freezer and top of the refrigerator they could be blocked with ice, if so we have a drain problem.
Let me know what you find and I will help you from there.
Apr 18, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Bottom freezer frosts up,top refridge gets warm
It sounds like you have a defrost component issue (e.g.: defrost thermostat, defrost heater(s) or defrost timer). Contact an appliance service company.
Apr 13, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer coils frost up within minutes after being turned back on
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 31, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Left the door open on my Freezer last night and now it doesnt wor
After looking at some advice from others I turned the internal dial to the OFF position, then turned it back to 6 or 7, and left it for 20 minutes, and it is now freezing again.
Jan 04, 2009 | Freezers
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Selected temp for freezer and refrigerator in not obtained. my milk and other foods are all spoiled. the meat from the freezer are not frozen. ice maker not making any more ice. I set the refrigerator at...
If the fan is running you more than likely have a defrost problem.
look at the back wall of the freezer section if it is frosted up.
If it is frosted up. it's not defrosting.
There three components in this system. The defrost heater, the defrost termination stat., and the defrost timer. Newer refrigerators do not have a timer per say it is build into a electronic board usually mounted on the back of the refrigerator under a metal plate. The termination stat is the cheapest part @ $ 25.00. The heater should run @ 50.00 to 70.00. The board could be as much as 200.00 or more. If the refrigerator is over 10 years old you may wish to look into getting a replacement. Appliances are designed to start failing after 10 years old.
My opinion.
If you unplug the refrigerator let it defrost then plug it back in. it will work properly about 3 days before it frosts back up.
Hope this helps
May 20, 2008 | GE Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
