Question about GE Spacemaker JVM1640SJ Microwave Oven
Runs normal but no longer heats anything. model # JVM1451BA 001 serial # RT9227675
  • 6,784 Answers
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Posted on Oct 06, 2009
My GE spacemaker xl1400 model JVM1451BA 001 DOES NOT TURN ON, serial # HT9897895 , it wont make a noise or nothing, not lights, someone told me its a fuse, but I dont know what the fuse is called to go to...
First try plugging it in a different power outlet to eliminate a possible defective AC outlet, than if it still does not work, your friend could be correct it could be a fuse, if you have electrical skills you can verify your self. first unplug the power cable, than unscrew the cover to get to the electronic board, locate all the ceramic fuses and with a good multimeter set to (Ohms) check the continuity of all fuses if it reads 0 ohms it's good if it reads nothing than it is bad, replace that fuse with the same amperage and type than put the cover of the oven back, plug the power cable and give it a test if the fuse burns again than the problem is much worse, it could be a defective safety switch on the door frame or a defective circuit board, take it to a good repair shop...
REMEMBER TO ALWAYS UNPLUG THE POWER CABLE BEFORE OPENING THE UNIT!!!
Hope this helps!
Jun 18, 2011 | Microwave Ovens
I have a model GE JVM1653BD 001 microwave. Sometimes when it runs it makes a loud growling sound. It appears to be heating normally though. Intermittantly makes this noise.
I have the same model ending in 003, and it has made this noise for most of its life of several years now. Every now and again it runs quietly.
My theory is the cooling fan (not the hood fan) is making noise. The problem began within the first year of operation, and up till now everything is in good working order otherwise. There is no odor of failing parts.
My installation book has no electrical circuit diagrams, and I came upon your question when searching the topic.
Oct 31, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool model number MH7140XFB no longer heats
you either need a new h.v. capacitor or h.v. diode in the magnetron circuitry if you cant hear it cycle when it runs as in a low pitched hummmm when its drawing current to operate the magnetron tube, each part runs about $30 to $45 each,normally its the h.v. capacitor though
Jul 28, 2010 | Whirlpool MH7140XF Microwave Oven
Mircowave runs but doesn't heat and it has a load hum.
You may need a new microwave..however, the diode may be defective or the magnatron tube may need replacing,,The magnatron tube is only warranted for 5 years so it may be used up as the model is (10years)fairly old.
Jun 18, 2010 | General Electric Microwave Oven
My GE microwave, model #WES1450DM1BB; serial #SM908139U, shows
When I try and heat some food, the microwave runs but doesn't heat anything, its a model wes1450dm1bb
Mar 15, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave stopped heating
The magnatron capaciter is burnt out (this is what heats the food!) it can be replaced but it may be cheaper to buy a new oneYjis should fix ya!
Dec 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't heat
its probally your magnaton
Mar 25, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
201 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
