Question about Mitsubishi WS-65712 65" Rear Projection Television
The blue convergence on my tv has gone out of sync and I cannot realign. does this mean the blue cannon is bad? if so, what's repair expense on this tv?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
If convergence will not adjust---the STK-393-110 CONVERGENCE IC this set uses is bad.
There is a simple reason this happens--this part is about 3 inches wide and 2 inches tall and has two rows of pins(it is black in color) the back of the chip is metal and a white grease is applied to it to transfer heat to the large metal heat sink it is bolted to keep it cool----after several years the grease dries out from the heat and the chip cannot move the heat fast enough and it fails.
You can buy a replacement IC on Ebay for about 11 dollars plus shipping---this part is located on the middle circuit board---if you remove the front speaker grill and the inspection plate behind it you will see it from the front of the set.
If you are able to remove the circuit board and know how to solder--most people can do this repair themselves---I can provide instructions.
If you cannot do this repair--shop around your area as most shops will charge 300-400 for this type of repair---if they say it "has to go to the shop" keep looking---any good tech can do this repair in your home in about 1 hour---I know as I have done hundreds of them.
Considering what the set cost new---usually this set is worth the 300-400 repair--you cannot replace it with a set of this size or quality for that price--I do lots of them here in peoples homes and charge about 250 total--house call, parts and labor.
IF YOU HAVE ANY QUESTIONS OR NEED ADVICE do not hesitate to ask me.
I am here to help people.
Regards, SD TECH
Posted on Oct 06, 2009
Convergency has gone out of sync, went to try to realign but the convergeny setting was not listed in the tools menu.
Thats usually caused by a blown FL231 Fuse and a blown DL231 diode that blow when the flyback transformer develops solder cracks around the pins. The repair is to first resolder the flyback then replace the FL231 fuse and DL231 diode. You can get the RCA / GE convergence option missing repair kit which has the parts and repair instructions from www.tvrepairworld.com
Jul 09, 2011 | RCA HD61W66 61" Projection HDTV
Blue lines .
the convergence IC's are failing to perform properly...
you might need to replace them
Mar 26, 2008 | JVC AV-65WP74 Rear Projection Television
Blurred picture red and blue shadows
Please run the convergence feature on your TV. Its giving you double image because the red, green, and blue guns are dis aligned. By running convergence it will realign the guns properly. You need to run the convergence feature at least once a week. Please note this is only for CRT rear projection TV's and I assumed it was. If it is an LCD rear projection, then there's nothing you can do to fix such thing, but call a repair person. But if doing the convergence doesn't fix the problem, you need to call a repair person. But I hope you won't have to refer to the manual on how to go about it
Nov 29, 2010 | Apex Digital GB55HD09W 55" Rear Projection...
I HAVE A DOUBLE VISION, BETWEEN THE GREEN AND RED, THE GREEN IS SOMEWHAT WARPED OR ARCHED.
Please run the convergence feature on your TV. Its giving you double image because the red, green, and blue guns are disaligned. By running convergence it will realign the guns properly. You need to run the convergence feature at least once a week. Please note this is only for CRT rear projection TV's and I assumed it was. If it is an LCD rear projection, then there's nothing you can do to fix such thing, but call a repair person. But if doing the convergence doesn't fix the problem, you need to call a repair person. But I hope you won't have to. Please refer to your TV's manual on how to do convergence and how to overlap the crosses because every CRT projection TV is different.
Jun 29, 2010 | Sony KP-51WS510 51" Rear Projection...
Blue and red colours separating
Hi, before I can help you, I need to know a few things like the brand and model of the TV. But I can tell you that either you need to realign your tv's convergence, or you need to replace the Convergence IC's and a few resistors. There are not to many parts in a Projection TV. From my experience, and depending how bad they are seperated, one of those two things are it.
Feb 15, 2010 | Televison & Video
Blue Convergence out of sync
you need to adjust the convergence. you set up convergence 1 then 2. follow the manual. (Its easy, you just align the + signs so they make one white one (instead of three green, red, blue) sounds like something or someone bumped the tv, causing the blue lens to shift a little.
Nov 23, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Blue shadow above writing and pictures on screen
it sounds to me like your convergence boarde is bad and needs replaced
Oct 23, 2008 | Televison & Video
Toshiba Cimema Series 55''
most probably the convergence is going bad, enter the menu and realign the converg. match the red to green and the blue to green
Aug 17, 2008 | Toshiba TZ50V51 50" Rear Projection...
3D Looking Colors
yes its most likely the STK392-110 ICs change both at the same time. You can get replacements at the following link with free instalation instructions.
http://servicemanuals.vstore.ca/
Jul 31, 2008 | Panasonic PT-53WX54 53" Rear Projection...
THE 3 COLOR LIGHTS DO NOT ALIGN
No....needs convergence circuit repair.Usually several hundred
dollars to change out convergence IC's..................T.
Please rate this solution.......................
Sep 24, 2007 | Sony KP-53HS10 TV
Mitsubishi WS-65712 65" Rear Projection Television Logo
158 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
