Question about Maxent MX42X3 42 in. HD-Ready Plasma Television
MX 42VM11\r\nP4202YD07 MX 42VM11 P4202YD07 Dec 2005 54973600653 Poster-ized colors and screen memory retention causing ghost siloutes
  • Maxent Master
  • 19,396 Answers
Screen image retention is caused by faulty plasma display, and often is considered beyond repair.
Try following the hints here to reduce the ghost effect.
Posted on Oct 06, 2009
Why is sharp mx2700 black ghosting ?
Check the fuser assembly and make sure the 2 levers for envelope printing are not engaged. They reduce the pressure between the fuser rollers and then the copies get issues like that. If that doesn't fix the issue Could be the drum or the transfer belt cleaning assembly causing this problem.
Sep 04, 2014 | Sharp MX-2700N Color Copier
IMAGE STAYS ON FOR AN LONG TIME
Sounds possibly like image retention. If you watch the same channels often any recurring text, logos, or graphics, especially white colored, can ghost on the screen.(playing the same videogame for a long period can also have the same effect) Watching other programs or channels will cause the ghosting to disappear.
To prevent image retention you need to activate the TVs anti image retention mode(Called ISM Method). On Zenith and LG (the manufacturer of Zenith T
s) plasma TVs open the TVs menu, select the Option section (picture of a briefcase with a wrench). Select ISM Method and change it to Orbiter, this is reccomended if you watch programs or channels (or play videogames) that have still images for long periods of time. It moves the image a little every couple minutes.
If watching others channels or programs doesn't make the image disappear, change the ISM Method to either Color Wash or White Wash (don't use White Wash frequently, it over excites the plasma gas and can shorten the life of your TV if overused) for a few minutes and then return to Orbiter.
Oct 23, 2013 | Zenith Z60PV220 60-inch Plasma TV
Dell E177FPB monitor has ghost images "bleeding"
I had dual monitor with color bleed to the right. The solution was
1) identify optimal resolution for both monitors ( Dell 198wfp @ 1400 x 900) and (Laptop @ 1200 x 800) 2) check colour setting (32 bit or 16 bit) 3) reduce colour setting down to 16 bit) 4) Check performance 5) reduce screen resolution 6) check 7) cycle between screen color and screen resolution 8) if no luck, check updating the drivers for graphic card 9) if no luck, check updating monitor drivers 10) if no luck, check altering memory set aside for graphics (onboard memory for example or off-graphics-chip-on-RAM-memory) 11) Monitor checking software is very helpful : try "http://majorgeeks.com/download.php?id=22" for the Nokia Monitor Test (a CRT tester) or any other freeware/shareware testing program such as passmark's products etc.,
You might just have to suffer with a large workspace and mungy grapics performance though ... I am.
Nov 22, 2010 | Dell Computers & Internet
Can I change the resolution on mx-42vm11?
Resolution is definded by the input. If you are receiving an HD signal it will display in either 720 or 1080.
The display is only as good as the input.
Dec 29, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Problem ghost features
If it's a flat panel plasma, then you may have a burnt image in the screen, known as "image retention". If it's a flat panel LCD, then it could be caused by a bad T-con board on the panel.
Nov 07, 2009 | Televison & Video
Panasonic PT-AE900u Horizontal Ghost Image/ 2:35 Image Retention.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
Jul 21, 2009 | Panasonic Televison & Video
I have a 3 year old Maxent MX-42VM11 plasma tv with no pic/sound
swollen capasitors, replaceing will cost $500, so best to get another one, 42'' samsung will sell for about $800. the pn42a450
once a plasma has a problem, fixing it or not, more problems will occure, trust me, i am the flat pannel guru.
May 02, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent mx-42vm11 screenflashes black and acts like it loses input
Check on ebay for the repair kit if you are versed with a soldering iron.
Apr 09, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent MX42X3 42 in. HD-Ready Plasma Television Logo
94 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
