When I turn the TV on it shuts itself off in two seconds. It's model WS65909 Diamond Series
My tv is sony wega kvbz14p40 it will shut off by it self after two minutes and it gives sound of relay what should i check
Posted on Oct 12, 2009
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
This model should have a self diagnostic feature:
Turn set on and when power light goes out----Press and hold on the front of the set both the MENU and INPUT buttons for 5 seconds and release both.
Power light should blink a two digit error code---most common is 2 blinks, a pause and 2 blinks--set will repeat the code about 10 times.
Let me know what the error code is and I will tell you what it means and what may be needed to fix it.
I am here to help people--If you have any questions or need help let me know.
Regards, SD TECH
Posted on Oct 06, 2009
I currently am experiencing my 2002 Mitsubishi diamond series tv shuttin g of after being on for 3-5 minutes
Sounds like you have a cooling issue. Do you notice if the fans inside the back of the tv are running? If not then it's overheating and turning itself off to prevent further damage.
Also The next time it happens, before you just turn it back on, press the INPUT and MENU buttons on the front panel together and hold them down for at least 6 seconds. This should cause the front LED to flash a 2 digit code. If it flashes once, then twice, then pauses and repeats, it means that the TV's computer didn't detect a problem.
Feb 28, 2011 | Mitsubishi WS-65809 65" Rear Projection...
My television suddenly turned itself off while switching from video to hdmi. Now it will only turn on for a few seconds and shows a "no signal" message, then shuts itself off.
We have a 42" Model XV42L HDTV10A 100-240V,2.5A,50/60HZ....when we turn the TV on the screen is flickering and then shuts itself off....sometimes it will come on for a few seconds and then shuts off
Dec 16, 2010 | Vizio 42 in. LCD TV
I have a Hitachi Ultravision Projection TV Model 57XWX20B. My TV will not stay on. I tried unplugging it, then plug it back in. It will then click once to turn on; then after 15 seconds it will turn off. ...
The power source detects an overload on one of its exits and shuts down to protect itself. The tv must be opened and tested by a knowledgeable person who can identify and replace the failed part.
Aug 22, 2010 | Hitachi Director's Series 57XWX20B 57"...
Ws65909 powers off about 3 sec after power on
a code will always read 12-normal if you just plugged the tv in. it has to try to turn on then shut itself down to log a code. Or shutdown is caused by something the tv cannot detect . Or a front panel button has failed- does the green light turn on for a second when you hit the power button on the remote? if not try unplugging the front keypad behind the speaker cover.
Oct 06, 2009 | Mitsubishi WS-65809 65" Rear Projection...
I HAVE A MITSUBISHI DIAMOND SERIES TV. I REPLACED
Sounds like your TV is overheating. How dirty is the filter on the side? Is the fan on the back turning ok:? Does it look real dirty? Is so, a good cleaning is in order. Also, there is a fan under the lamp. Can you determine if it is working...the air flow may be obstructed (from the clogged filter) and it takes some additional time to cool.
Jun 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
When I power up, 5 seconds later this back projector TV turns itself off
t does sound like a bulb problem, either its over heating and shutting off to protect itself, or its already shot. Give a TV repair shop a call and see if they can give you an approximate price, then decide to ditch or repair it.
May 30, 2009 | Televison & Video
Screen went dark
can you confirm make and model number please.
Dec 10, 2007 | Mitsubishi WS-55807 TV
Mitsubishi ws65909
Yes,but first it is necessary to repair the problem = replace
both STK392-570 IC's.............Then use remote to adjust
convergence............."inside the tv" is called servicer menu = adjust after repair is complete.You can expect to replace IC's
every five years or so.......................T.
PS Try to match your problem thread model # to actual model #
ie. VS-5043 does not match WS-65909........T.
Nov 25, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Intermitent Shot Off
Please check the sleep timer is off..
Sep 23, 2007 | Mitsubishi Diamond WD-65831 65" Projection...
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
