Question about Canon PIXMA MP780 All-In-One InkJet Printer
Canon PIXMA MP780 "cannot print because printer head overheated"
My Canon PIXMA MP780 printer, which was working perfectly, suddenly stopped working. It can no longer print or photocopy. This happened after a thunderstorm when I was talking on the phone and my computer was on. I lost that phone call during the storm. Since my internet, TV and phone service are all linked, could the problem with the printer be connected to the thunderstorm? When I try to print, the printer shoots out blank sheets of paper. The printer displays error message #336 and "cart. incorrect". I've checked the ink cartidges, taken them out and put them back in, and they seem no different from usual. When I try to print I see in the the printing window on my computer the message "cannot print because printer head overheated". I tried unplugging the printer for 24 hours to let it "cool off", but this did not help. I still get the "overheated" message. Is my printer fried?
SOURCE: canon pixma ip90 printer
if your printer is flashing 4 orange and then back to green repeatedly - i found a solution to it for my ip90v - i opened the printer and checked the right hand side cogs - carefully turn them and you may see that some stray paper jam debris is blocking the cleaning unit from returning to its home in the bottom front of the printer - carefully remove it and replace the casing - turn on and with any luck you will have a dully functioning ip90 like i did.
Hope it helps some others out
Posted on Dec 13, 2008
  • 153 Answers
SOURCE: Canon printer not printing and gives error code U052
you have a purge unit problem, cost more than the printer is worth unless it is under warranty,
Canon small printer technician
Posted on Apr 01, 2009
  • 92 Answers
SOURCE: The 3eBK head stopped printing.
Try below some steps which might help you resolve the problem.
Print Head Cleaning / Head Refreshing If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
  1. Press the <Menu> button on the printers operation panel repeatedly until [MAINTENANCE] appears in the LCD.
  2. Press the left [<] or right [>] arrow buttons to select the cleaning setting you want. Select [HEAD CLEANING] or [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  3. Press the <OK> button.
  4. Print a Nozzle Check Pattern and perform at least two Head Refreshings if the pattern is not correct.
If this does not help, try removing the print head and then install it again. Once place, dont forget to aligh the head. Following are the steps:
Reseat Print Head Reseating the print head is seldomly needed to be done.
  1. Press the Open Button (1) to open the Paper Output Tray (2).
  2. Raise the Scanning Unit until it stops.
    1. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.
    2. The Print Head Holder moves to the middle.
  3. Open the Inner Cover 1.
  4. Open the Inner Cover 2.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  5. Press the ink tank's tab (1), then remove it from the slot (2).
    IMPORTANT:
    Handle ink tanks carefully to avoid staining clothing or the surrounding area.
  6. Lift up the lock lever and take out the print head.
  7. Again, place the print head back in position and press down the lock lever.
  8. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard. Make sure the ink tank is in the correct slot.
    IMPORTANT:
    a. Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
    b. If the ink tank is inserted in the wrong slot, perform two head refreshings.
  9. Close the Inner Cover 2.
  10. Close the Inner Cover 1.
  11. Pull the Scanning Unit Lever towards you to close the Scanning Unit.
  12. Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.
Automatically Aligning The Print Head Position:
  1. Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].
  2. Press <Menu> repeatedly until [MAINTENANCE] appears.
  3. Press left or right arrow to select [AUTO HEAD ALIGN].
  4. Press <OK>. The print head position alignment pattern prints.
  5. Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete.
Manually Aligning The Print Head Position:
  1. Load A4- or letter-size plain paper in the paper support or cassette.
  2. Select the paper source with <Feed Switch> button.
  3. Press <Menu> repeatedly until [MAINTENANCE] appears.
  4. Use left or right arrow to select [ALIGN PRINT HEAD].
  5. Press <OK>. A horizontal pattern is printed.
  6. Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
    (1): Bad example (Least solid box)
    (2): Good example (Most solid box)
  7. Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.
    (A): Column
    (0): Select pattern number with most solid image
  8. Press <OK>.
  9. Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].
  10. Press left arrow. A vertical pattern is printed.
  11. Beginning from column M on the printout, enter checkmarks in the patterns that have the most solid image.
  12. Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.
  13. Press <OK>.
  14. Repeat steps 12 and 13 to adjust column N.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 26, 2009
michael_grey
  • 365 Answers
SOURCE: mp780 wrong cartridge error
Try to reset to factory .
Remove ink cartridges and print head.
Power off machine and unplug for 10-15 minutes.
Restart machine and install head and cartridges.
Posted on Jun 17, 2009
SOURCE: Canon PIXMA MP190 'not responding'
I was able to print a few documents and after that I just changed the b/w cartridge and not the colour one. I have used the printer on very few occasions, and when I tired to print again. On my computer it says 'looking for printer'. Yes when I check my systems on my computer its all there. Do both cartridges have to be changed in order for the printer to work?
Posted on Nov 22, 2009
My mp780 will not print light cyan or magenta...It prints all the dark colours on the print test perfectly but leaves the light ones missing. I have tried a new printhead and it has new canon cartridges....
Most likely the print heads are dirty and need to be clean. The user manual for the Canon should tell you how to do that, but in case you don't have the manual, you can get it here: http://goo.gl/iIylF
Mar 06, 2011 | Canon PIXMA MP780 All-In-One InkJet...
The color of my PIXMA MP780 printer has problems
clean the head of the ink. then do the calibration for canon.
Jul 02, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Print head, some nozzles blocked
the print head is defective and print head control board, need replacement. normaly very expensive spare parts, above printer price.
Dec 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Mp780 wrong cartridge error
Jun 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Print head overheat
You can buy a new printhead, if that is the problem. did you try printing after the machine cooled down?
Try going on eBay and search for an MP780 printhead...it should cost about $50-60 or about $60-85 elsewhere, check Canon too.
Possibly, a cleaning kit might unclog anything plugged, though a electrical problem is probably fixed only with a new head. New heads snap in to the printer...Good Luck!
May 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Colours have suddenly become washed out and lime green.
I read a lot of complicated stuff about cleaning the print head after my similar problem this week. Finally I found an old, soft toothlbrush, gave it a very light spray with windex and lightly brushed the magenta print head. I put the cannon cartridge back in and everything is printing perfect again. This worked for me, good luck to l you.
Dec 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
PIXMA MP780 "WRONG CARTRIDGE" MESSAGE?
Here is what I did and it now works just fine.I turned off the printer and unplugged the power cord, and unplugged it from my computer. I then removed all the ink cartriges and removed the print Head I got some rubbing alcohol put it on some toilet paper and wiped down the back and bottom of the print head.Plugged everything back in and It now works better then ever.
Feb 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
605 people viewed this question
old marine
old marine
