How can i connect my sharp lc-26sh10u hdtv to laptop
Im tryeng to find how to connect my tv to laptop
    Sniper:
  • 108 Answers
Sharp had a standard VGA socket on it?, with an adaptor for connecting Component to it (via unused pins). but presumably you simply connect via a VGA lead and select the PC input on the menu
ure HD is cool on a computer monitor, but it's nothing like a huge HDTV.
How you do this will depend primarily on your PC and your HDTV. Lucky for us that they both share some common interfaces. The most common interface is DVI for computers and component for HDTVs. You have a few options here. S-Video and Composite won't work because they only carry SD signals and what fun would that be?
Before we get started I want to mention that all TV's are subjective to some overscan, yes all, but some more than others. At the very least 2% and at the very most 10%. Normally you don't notice, but when displaying your desktop on your HDTV even a small amount of overscan is noticeable. If you plan to watch movies and other videos it won't bother you. If you are planning to surf the web or play video games it can be more intrusive.
If you are one of the lucky ones who have a DVI port on your computer and a DVI or HDMI port on your HDTV. You can buy ahow can i  connect my  sharp   lc-26sh10u hdtv  to - 180px-video_standards.png cable and set your computers output resolution to one that is supported by your HDTV. That is This seems pretty simple, but unfortunately it isn't always that simple. HDTVs and computer monitors don't always support the same resolutions. All the video standards are covered in this image. It is confusing but useful. The main thing to pick up from the image is that PC's don't use the same native resolution as HDTVs. Some HDTVs can accept standard PC resolutions like my Sharp AQUOS. To see which resolutions your HDTV supports check out the manual. Most companies have their manuals online so if you don't have yours head over to the manufacturer's website to look it up.
As you can see from the grid my HDTV supports most resolutions, the other great thing about this TV, is that there is no overscan at PC resolutions, but there is at normal HDTV resolutions. Unfortunately this is not the norm, but if you are one of the lucky few then you can grab a cable and connect it.sharpres_small.jpg
You can use VGA, component , DVI or HDMI to carry HD signals. Since digital is generally preferred you should use either DVI or HDMI. If your HDTV has a HDMI and since no computers have HDMI yet you will need to use an adapter from DVI to HDMI. Lucky for us, HDMI uses the same signaling technology as DVI.
Before you plug in your DVI cable from your PC to your HDTV be sure to set the resolution to one that is compatible with your HDTV. If your computer monitor and your HDTV only share one common resolution, set it to that until after you get a picture on the HDTV, then change it to the desired resolution. When possible always try to use the displays native resolution. For example my Sharp AQUOS's native resolution is 1280x768.
If the desired resolution isn't available from the display controls of your PC then you will need to add it. You can use apstrip_small.jpg great piece of software called Powerstrip to do this. Install it and then add the desired resolutions. To add a custom From here you can add a preset or user defined resolution. If your TV only accepts 1080i then use "1920x1080i 60hz". resolution to PowerStrip go into display profiles, then "Advanced timing options", then choose "Custom Resolutions". User defined resolutions are beyond the scope of this guide. The best article I have ever read on how to do this, is at the AVSForum. So check it out, but keep in mind that Powerstrip includes most of the HD resolutions for you, so you don't have to copy and paste the timings in yourself as described in the article. If you are a Mac user look for DisplayConfigX. Linux users need to add the custom resolution to their xorg.conf, you can find help vgatocomponent.gif
Unfortunately for most of us, it isn't this easy. Most HDTVs only accept a few resolutions and some only have component input. Since most PCs don't have component output, it can be a bit more difficult. Your best bet is to either buy a video card that supports component output like a Radeon X600, or to buy a VGA to component converter. Since the convert costs as much as a good video card, it usually makes sense to go with the new Video card. When shopping for a video card keep in mind that sometimes the adapter doesn't come with the card, even though the card supports it. My Radeon 9700 required me to buy an additional $29.99 adapter to unlock the component functionality. Luckily most of the newer Radeon cards now come with the cable. As always when using a cutting edge video card be sure to use the latest driver. But don't be scared to roll back a few versions if you have problems. The latest Radeon drivers have HDTV resolutions built right in, so there is no need for Powerstrip. You can still use it to tweak your setup if you want, not to mention the other 100 things it is good at. If you end up using the VGA to component adapter, then you will need Powerstrip to setup the correct resolution. Don't be afraid to try different resolutions to find the best one. I find that because all HDTVs have overscan, non standard HDTV resolutions can help to eliminate the overscan. It is important to keep in mind that it is possible to break your TV by sending it the wrong resolution. So make sure you understand what you are doing before you start to experiment too much. I wouldn't use any resolutions that is not preset without first reading the thread over at AVS.
Try it ..All the best
Posted on Dec 23, 2007
    President:
  • 1,944 Answers
Does your laptop have svideo out/HDMI or RCA component video out?
  • Damen Wong
    Damen Wong Dec 23, 2007
    What is the model name/number of your laptop?
Can I hook up my Toshiba laptop to my Sharp Aqous TV, if so what connections do I need, ?S-video? I have an SGA connection on my laptop but not on the TV?
If this is the exact model Sharp Aquos television you have then you would have to have a laptop that has hdmi or dvi. You can try S Video on a laptop but the laptop's resolution would have to be so low that most laptops cannot accommodate this. You're right; this television does not have a VGA (RGB cable) input.
Nov 02, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I am trying to connect my sharp liquid crystal tv LC26SH10U, to my laptop and am unable to do it, I wanna use this tv as a monitor.
I have this same model TV & am using it as a second computer monitor. I have mine running through an HDMI connection on input 4. I will mention it runs at 1280x720 recommended. I'm not sure if it's the display or just my video card, but mine can handle UP TO 1920x1080. Something to note, however, is that the TV has a natural refresh rate of 60 Hz. Check your video settings that they can handle that (or at least an even integer thereof). My card (ATI HD 5750) is running it at 30 Hz with some minor issues.
Final point: if you want the sound to pump out of your TV as well, remember to change the default sound device in your volume control panel.
Oct 25, 2010 | Sharp LC-26SH10U 26 in. LCD Television
Sharp digital tv cannot receive digital signal
This television would benefit from an hdtv indoor outdoor amplified antenna not obstructed by trees, aluminum, bricks, and etc. Make sure the signal type is air and not cable and complete a channel scan during primetime tv hours after connecting to this antenna. Buy a large one that you can mount to the wall usually in a large flat box on the shelf in the store. Philips has one sold at Walmart.
Jun 07, 2010 | Sharp LC-26SH10U 26 in. LCD Television
Lost the red color from my Sharp LCD TV
Reboot ur HDTV box buy unplug and replug is an hour later,see if get the color back.If not,than ur Sharp tv Main Tuner signal board is dead that the problems,must replaced the Tuner signal board to solved this problems.
Mar 05, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-37GD8E ... IM VERY SOORY TO BODER YUO BUT MY TV WONT START AT ALL SERIAL 610414045 thx
i find that my aquos lc37gd8e has no signal between 5pm and 6.30pm but my other tv is fine it also switches itself of somedays at 9.30pm have trided retuning this has not helped can you help?
Nov 26, 2009 | Sharp Aquos LC-37GD1E 37 in. HDTV-Ready...
My SHARP LC-26SH10U PROBLEM. POWERS RED THEN GREEN WHEN I PRESS POWER, THEN SCREEN GOES BLUE AND THE MESSAGE "PLEASE WAIT" APPEARS...AND THATS ALL I GET. I TRIED HOOKING IT TO MY COMPUTER VIA THE USB...
HI, you will need to replace the Digital PCB in this unit. the chip set has become unstable. there is some major circuit damage as well. AKA(PWB UNIT)
Sharp Part Number: A3Y004GDH0 $262.95
Jun 19, 2009 | Sharp LC-26SH10U 26 in. LCD Television
No power; no "red light" indicating standby
you can sell it to me or i can sell you mine so you can get it fixed. its the motherboard. i got one but with a broken screen.
Mar 19, 2009 | Sharp LC-26SH10U 26 in. LCD Television
Sharp lc-26sh10u intermitent problem
its a motherboard problem. i got one for sale or you can sell me the tv cause mine has a broken screen
Dec 25, 2008 | Sharp LC-26SH10U 26 in. LCD Television
Show Microsoft Power point on Sharp Aquos hdtv
try to right click the desktop and choose graphics options, you will have to select the correct output for your setup. i.e. laptop to monitor, etc etc see if that works,...sounds like you have a connection, you will have to play with these settings until it pops up. worked with a similar scenario, sometimes you have to do stufff twice and it works on the second time not the first, electronics are weird.
keep changing the settings in the graphics options until it comes up the way you want it.
Nov 13, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
350 people viewed this question
Top Televison & Video Experts
