Question about Refrigerators
Need to know what water filter to replace on # LFX25971st-1
  • 1,543 Answers
Use a 5231JA2006A filter.
Posted on Oct 06, 2009
  • 80 Answers
LT600P
How and where do you change water filter
From the KitchenAid Manual:
The water filter is located in the upper right-hand corner of the
refrigerator compartment.
Replacing the Water Filter
To purchase a replacement water filter, model 67003523 Part
Number 4396395, contact your dealer or call 1-800-442-9991
U.S.A. or 1-800-807-6777 Canada.
IMPORTANT: Air trapped in the water system may cause water
and filter to eject. Always dispense water for at least 2 minutes
before removing the filter or blue bypass cap.
1. Turn filter counterclockwise to remove.
2. Remove sealing label from replacement filter and insert the
filter end into the filter head.
3. Turn the filter clockwise until it stops. Snap the filter cover
closed.
4. Flush the water system. Depending on your model, see
"Water Dispenser" or "Water and Ice Dispensers."
NOTE: The dispenser feature may be used without a water filter
installed. Your water will not be filtered. If this option is chosen,
replace the filter with the blue bypass cap.
http://www.kitchenaid.com/digitalassets/KFCS22EVMS/Use%20and%20Care_EN.pdf
May 16, 2014 | KitchenAid KFCS22EVMS French Door Bottom...
Water leak behind ice bin
likely so unless you can get the seal ring. However, it first needs to be determined which part causes the leak as they can be many sources
Dec 10, 2017 | LG LFX25971ST Bottom Freezer French Door...
My LG LFX25971ST quit making ice
First check to make sure that you are getting water into the ice tray. If not it is most likely the water inlet valve not supplying water to the ice maker.
If it isn't ejecting the ice, it could be either the motor or the thermostat.
Aug 14, 2011 | LG LFX25971ST Bottom Freezer French Door...
The ice maker will make at most 36 cubes of ice. this is from day 1 of owning the #$()$ thing. The manual states it should make 80-120 cubes a day. We have had the ice maker replaced three times. The...
check water filter, water valve.,what state do u live?
if wisconsin , need to check city water
i can get more infromation for u. not now. how about tomorrow.
please sent me e mail
i live wisconsin. i try my best to fix ur problem
good lock
i fix many ice maker and ice machine every year
Jan 12, 2011 | LG LFX25971ST Bottom Freezer French Door...
Water flow of filter too slow
When was the last time you changed the water filter? If the filter is clogged from long usage it will slow down the water flow. Filters should be changed 6-12 months.
Jul 11, 2010 | LG LFX25971ST Bottom Freezer French Door...
Ice Maker Hookup for LG side by side with freezer on bottom. We connected the water line to the fridge to the connection in back.... both connections, the one up top and the one on the bottom. We are not...
ok...1st there is only one connection to the fridge at the valve.2nd check the filter and see if one is present.3rd make shure the child lock out feature on the dispencer is not activated.
Aug 06, 2009 | LG LFX25971ST Bottom Freezer French Door...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
