Question about Polaroid IDF-1030 (826219006783) Digital Picture Frame
Hello, My parents purchased me a digital Poloroid photoframe and i have downloaded my photos onto it but it keeps sticking and wont move on to the next picture. Also there is about 6 photos which are causing the frame to stick which it wont let me delete either. Do you have any advice.
  • 121 Answers
My first thought would be to format the entire memory. Then put the pictures on a couple at a time and see how they work.. It's possible that the coding on a couple of the pictures is corrupt and that would cause the type of symptoms you describe..
Beyond that I'd return it to the shop as it should be straightforward to set up and use..
Hope this helps.. :-)
Posted on Oct 06, 2009
  • Marvo2 Oct 06, 2009
Philips Photo Frame Failed to load executable file
Download the last Firmware-File from Philips and extract it. In the extracted folder is a file called execute.bin. This file must be moved over the Micro-USB-cable to the internal root folder. After a restart the photo frame should be automatically install the last firmware.
Dec 02, 2012 | Philips PhotoFrame -10 Digital Picture...
I just bought a digital photo frame for my husband for christmas and i get so many pictures downloaded...then it just stops and says insufficient memory card.....i thought there was something wrong with...
I'm pretty sure this means that you have filled up the internal memory on the picture frame.
I just bought my sister a photoframe for Christmas (made by Phillips) and we got the same message. Not the most precise wording on the error message, but we tried deleting a few photos and the error went away. Then I checked the internal memory of the frame, and it is only 128M, which is not alot of photos.
I think the solution will be to buy a USB memory stick to leave in the frame. For about $10 you can get a 4G USB memory stick, which is about 32 times the space of the internal memory, at least if you have a similar model as we do.
See here: http://www.amazon.com/USB-Flash-Drives-Storage-Add-Ons/b?ie=UTF8&node=3151491
Dec 23, 2010 | Philips Cameras
I have bought the philips 10.4 inch digital photo frame and im trying to put pictures on it and store them in the internal memory. When i put my card in it starts to install them but then says not enough...
Tough the picture frame states 1000 photos, it really depends on the size of the picture. To resolve this purchase a 2 or 4 gb memory card and download your pictures onto the card. You can insert the card in the slot of the picture frame and then connect to your computer and download your pics from your computer directly onto the memory card.
Dec 14, 2009 | Philips PhotoFrame -10 Digital Picture...
Sony Cybershot - the memory stick is full
More than likely the camera still thinks the photos are on the stick, especially if you deleted the images while it was hooked to the computer. I would safely move the rest of the photos off the stick onto your computer then format the card through the camera and with the camera disconnected from the computer. this should clear the card.
Feb 03, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
Downloading photos from computer to phillips 8ff2fpb photoframe
Your PhotoFrame does not have internal memory acording to the Phillips data sheet, therefore you need to load your pictures directly onto a memory card (one from your camera will proabably work.) If that isn't convenient, you can generally get a good price on a SD memory card which is supported by your PhotoFrame.
If you wnat to transfer pictures from your PC to the memory card and have a card reader, you can transfer the pictures in Windows Explorier from your PC to the memory card and then plug the card into your PhotoFrame. If you do not have a card reader, plug the memory card into the PhotoFrame and connect it to your PC using a USB cable (you may have to buy one as acording to the Phillips data sheet it is not supplied.) When the PhotoFrame is pluged in it will appear in Windows Explorier as a new hard drive, and you can copy your pictures to it.
I hope this helps,
Mike
Jan 03, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
It was my birthday last week , and my boyfriend bought me photoframe (digital) i hav manged 2 set clock, but cant seem 2 figure out how 2 get photo's from my laptop on 2 it , i hav manged 2 use a memory...
hi there
most photo frames don't come with a built in memory so you would need to check the manual.
if it hasn't then you will have to put them all on a memory stick. a 2gig stick will hold about a thousand pikkys. if it has got a built in memory you just need to copy them on to it. post the make and model number and i'll sort it out.
beergut707
Oct 13, 2008 | Philips Cameras
How do I load pictures from my computer to the memory card in my camera?
You have to first download the images to your computer and Save them in a folder. Then connect the USB cable from the digital photo frame to the computer and transfer the photos you want onto the frame. Some time you have to change the photos name to alphabetic order so you photoframe will display the pictures in the correct order.
Feb 20, 2008 | HP Photosmart 635 Digital Camera
Sizing digital photos to display in digital frames
Use the 16:9/4:3 key on the remote to toggle between widescreen and normal view. Most digital camera photos look fine at 4:3.
Dec 26, 2007 | Cameras
Polaroid IDF-1030 (826219006783) Digital Picture Frame Logo
253 people viewed this question
Top Polaroid Photography Experts
Joseph Coppeto
Joseph Coppeto
Duke Mcadams
Duke Mcadams
Level 1 Expert
Are you a Polaroid Photography Expert? Answer questions, earn points and help others
