Question about Hand Tools
Any installation specs on the best way to install the vise on a wood bench?
  • 42 Answers
This is just generic instructions just to give you an idea of placement and mounting. I am not sure if your vise turns or not and that would be a big factor also. It depends on where you want it, if anything is close that will interfere with the vise or whatever you have in the vise. Depends how thick the spot is where you want to mount it. If the place is not very thick, use bolt and heavy washer on top of the vise and a heavy washer, a lock washer and nut on bottom. In place of the lock washer and nut, you could use locknut. If the bench where you want to mount is too thick for bolts, use at least 2" lag bolts with heavy washers with the lag bolts as big as the vise holes will accept. You will need the vise as close to the edge without it hanging over the edge of the bench. This is so you will be able to open and close the vise without obstruction. If placement of the vise isn't a big deal, the center edge of the bench would be great although I always mount mine on one end of the bench because of better movement of the part in the vise. Goodluck.
Posted on Oct 11, 2009
What do i need to know about installing wood floor
What type of wood flooring is it, is it glue down or nail down, engineered ( like plywood) or solid? Is the subfloor wood or concrete ect.
Always follow manufactures specs as far as acclimation, type of adhesive and expansion joints.
Feb 26, 2016 | Building Materials
Tip
Outdoor Wood Stove Hot Air or Hot Water
You're getting a new wood stove and you have many decisions to make. Other than brand, you need to decide whether you will use hot air or hot water to get the heat from the wood stove to the living space.
If you have a hot water heating system already installed then you obviously need to have a water stove. If you are thinking about what to install in a new home or already have hot air then you need to consider what will be the best option for you.
Now if you are installing a new system then you want to go hot water. That is by far the best way of heating and will be the best way to heat using an outdoor wood stove. Hot water heating is one of the best ways to get great heat transfer from the fire to the water to the air.
If you have hot air heat and want to heat with wood then you can install a wood hot air furnace, and set it beside your existing furnace. The ductwork will have to be reworked to get the heat from the wood furnace to the existing ductwork. Or you can install a coil into the ductwork on the supply side of the furnace, for the water to run through from a hot water wood burner. This is probably the best way to heat if you have a hot air furnace. Installing the hot water coil is a very simple process and the piping is fairly easy to hookup.
Hot air wood furnaces are almost always a inside the structure appliance, which means that you have the mess of the wood and the ashes inside. This dust and dirt mess is something that is much better kept outside where it can be cleaned up much easier.
Bottom line here is that you want to use a hot water wood burning stove if you can. You will be much happier with the heat that you get from burning wood.
on Dec 08, 2009 | Heating & Cooling
How do I depress the timing tensioner on a 2001 chrysler sebring 2.7l
You use a bench vise, and stick a drill bit or pin in the hole to retain it until you are ready to release it after you install it on the block.
Mar 29, 2015 | 2001 Chrysler Sebring LXi
CS9527
This is a tedious task but you can do it without taking anything apart the best think I've found is to go to small engine parts store and get the same size (fuel line) don't let them give you air line . Find a good long pair of tweezers and a bench vise you can bend them enough to be able to get into the fuel tank and connect the fuel line and away you go.
Mar 28, 2014 | Oregon Scientific Oregon 16-inch Pro-guard...
How to remove power steering pump on a 2007 subaru b9 tribeca
before start job suction out power steering fluid out of pump using large sirenge or siphon pump then.you need a table vise and two pieces of wood.okay to remove power steering pump. you need to disconnect the ground cable.remove air intake duct.remove the pulley cover.remove the drive belt.disconnect power steering pump switch connector.disconnect the pressure hose and the suction hose from the power steering pump.cover power steering hose and pipe keep getting trash dirt and debris.remove the installation bolt of the power steering pump bracket.place the oil pump bracket in a vise btween two pieces of wood keep from damaging bracket and remove the two bolts from the front side of the pump.remove bolt from rear side of the oil pump.disassemble the oil pump and the bracket by inserting flat tip screw driver.to install tighten oil pump to bracket bolts 12 ft lbs. tighten the bolt from the rear side of the oil pump to 27 ft lbs.tighten steering hose eye bolts to 30 ft lbs.replace fluid bleed air out power steering system.
Nov 28, 2012 | 2007 Subaru B9 Tribeca
Power steering pump, broken, how to replace
Power Steering Pump - REMOVAL & INSTALLATION
3.0L OHV (2 valve) Engine
(see Figures 1 and 2)
Fig. 1: Power steering system-3.0L OHV (2-valve)
Fig. 2: A few special tools are required to remove and install the pulley on the power steering pump
  1. Disconnect the negative battery cable.
  2. Remove the accessory drive belt.
  3. Remove the alternator.
  4. Drain and remove the radiator coolant recovery reservoir.
  5. Position a drain pan under the power steering pump underneath the vehicle. Disconnect the hydraulic pressure and return lines and allow to drain.
  6. Remove the idler pulley from the power steering pump support.
  7. Remove the bracket mounting bolt located under the belt tensioner mounting.
  8. Remove 2 retaining nuts from the bracket mounting studs. Remove both mounting studs, and pull off the power steering pump support with the pump attached.
  9. Clamp the pump support bracket in a suitable vise.
  10. Remove the power steering pump pulley from the pump shaft using Pump Pulley Remover T69L-10300-B, or equivalent. Remove the 3 bolts retaining the power steering pump to the power steering pump support and remove the power steering pump.
To install:
  1. Install the power steering pump to the power steering pump support.
  2. Install the power steering pump pulley using Steering Pump Pulley Replacer T65P-3A733-C, or equivalent; the pulley face must be flush within 0.010 inch (0.25mm) of the pump shaft.
  3. Install the power steering pump/pump support and torque nuts/bolt to 17-24 ft. lbs. (23-32 Nm).
  4. Complete the installation by reversing the removal procedure.
  5. Fill the power steering reservoir with power steering fluid.
  6. Connect the negative battery cable.
  7. Run the engine and check for leaks and proper operation. Bleed the power steering system if needed.
Hope this helps.
Sep 06, 2010 | 1996 Ford Taurus
How do we install a burner on a fireplace?
Thinking of adding a fireplace or wood stove to your home? If so, proper installation and maintenance is absolutely critical to ensuring the fire stays inside your freestanding fireplace or wood stove and doesn't venture outside of it.
If your manufactured home already has a fireplace or wood stove, it's a good idea to go look over these safety guidelines to confirm that it was installed correctly. If you plan to install a fireplace or wood stove, follow these safety guidelines carefully.
First, don't try to tackle this project yourself. While installation manuals usually provide all the instructions necessary for a manufactured home owner to install a wood-burning fireplace or wood stove, the consequences of a mistake are so disastrous, it's a task best left to experts.
It's a good idea to first check with your insurance company for their guidelines before installing these items. Your insurance policy may not cover damages if a fireplace or wood stove was not professionally installed. Plus, the manufacturer's warranty on the fireplace or wood stove may not apply unless the unit is installed by a professional.
Also can check this ARTICLE for other details.
Hope helps.
Jun 02, 2010 | Heating & Cooling
I can't get u joint out of driveshaft. Please help
You'll want to put it in a vice and heat it up untill the plastic oozes out. Then use a drift to knock out the u-joint one way then pull out the bearing cap and then same thing back the other way.Clean the holes with some emory cloth before installing the new one.
May 31, 2010 | 2003 GMC Sierra 1500
How do I replace the u joint on a 2003 suburban?
remove the drive shaft
remove retaining clips from bad u-joint
mark yoke so it can be installed in the same position
press joint out with bench vise or shop press
install joint with vise or press
lubricate joint and reinstall drive shaft
Mar 07, 2010 | 2003 Chevrolet Suburban 1500
My rattle gun 18V LXT Impact Driver BTD141 has a double ended Philips stuck in it? how do i get it out?
There are a couple of ways to try to free the bit from the drill chuck. But slow and steady is the key, don't hit anything too hard, so as to not damage the chuck in the process, nor break off the bit in the chuck.
You'll need to put the bit into a bench vise and reverse the drill slowly and carefully. Make sure the bit is tightly secured in the vise and that the drill won't spin your hand around and slam it into the bench when you pull the trigger.
As a last resort, you can try tapping the bit sideways, to get it loose. With chuck opened up all the way possible, gently tap the bit sideways. This should also free the bit, but be very careful not to snap the bit off in the chuck, or you'll have a worse situation trying to get a broken bit out of the chuck.
If none of these work, you can attempt to secure the stuck bit in the bench vise and try to tap the drill chuck using a hammer and a flat brass bar resting against the drill chuck, so you don't damage the chuck. Just tap the brass bar to drive the chuck free of the stuck bit. You have to watch the bit in the vise to make certain it's not slipping and that the chuck is getting free.
Hope you find this Very Helful and best regards!
Jul 12, 2009 | Drills
Hand Tools Logo
47 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Dan Apthorp
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
