Question about Xerox WorkCentre Pro 580 Plain Paper Laser Fax
I always got paperjam when i place paper in the
I have a xerox workcentre 580 I always got paperjam when i place paper in the slot
  • 239 Answers
If you can get the new feed roller, it does require some extensive work to get out the unit and replace the roller. Most the covers need to be taken off and to replace the roller requires one not to break parts putting on the new roller.
Call Xerox if all else fails.
Posted on Nov 01, 2009
    President:
  • 2,072 Answers
Most likely the feed roller is work out.
Posted on Oct 06, 2009
I have a Xerox, Workcentre 580 and I am getting a fuser error
On this model, the heat roll has a temperature sensor. If the heat roll is worn and coated with toner, this will damage the sensor. Most common problem is this sensor goes out when a heat roll is badly worn. Circuit boards on this model are pretty reliable.
This sounds like a fuser rebuild.
Feb 16, 2011 | Xerox WorkCentre Pro 580 Plain Paper Laser...
Can this fax machine be program with a code for security purposes?
No, in this Xerox machine this isn't possible; this and other details could find in the WorkCentre_Pro_580 UserGuide
I hope this help.
Sep 30, 2010 | Xerox WorkCentre Pro 580 Plain Paper Laser...
Blank page when I copy or print reports
Re check all the connections. When taking off the paper feed assay, other parts and plug and jack connections were needed to be taken off first.
Make sure the drum seats in its correct position, silver grounds are not bent.
The copy cartridge and Dev housing are not connecting very good somewhere.
Make sure the machine is unplugged.
Try running copies.
Apr 21, 2010 | Xerox WorkCentre Pro 580 Plain Paper Laser...
It does everything but always says paper jam 0 and no jam there when I use the paper tray
try rebooting the machine as this resets the sensors after the machine having a paperjam
Nov 27, 2009 | Xerox WorkCentre 3119 Laser Printer
I need the part # for a pickup roller
If anything else fails, call Xerox and ask for parts support. They might be able to sell you the part. Keep in mind you might have to purchase the whole paper feed assembly, not just the roller.
good luck.
Sep 10, 2009 | Xerox WorkCentre Pro 580 Plain Paper Laser...
My plain paper will not feed to print incoming fax????
If it is a WCP 580. clean the feed tire very well with something like formula 4009 then rinse it with alcohol.
Most likely that feed roller is cracked and worn. Will need replaced.
Jul 01, 2009 | Xerox WorkCentre Pro 580 Plain Paper Laser...
I need the manufacturer part number for the fuser to a WorkCentre Pro 580 - Xerox.
Call 1-800-828-5881 and follow the prompts. They will give you the part number you need.
Dec 15, 2008 | Xerox WorkCentre Pro 580 Plain Paper Laser...
Xerox WorkCentre Pro 580 Plain Paper Laser Fax Logo
185 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
