Question about Canon PC1061 Copier
Is there a fuse? plug in and no power... After fix
    President:
  • Canon Master
  • 990 Answers
Hello sir; Yes, there have a fuse on the power supply board.
Posted on Oct 06, 2009
How to fix my flat screen t.v.?
Check all the AC input connections. As the power board is new, the TV should show standby light at least, when you switch it ON.
Check whether there is a line fuse inserted at AC path. Check whether there is a plug-fuse included inside the power plug.
Jul 16, 2015 | Toshiba Televison & Video
Phillips Television Model: AK01 will not power on when plugged in. Why?
there is a fuse in the back of the set . It is normally a small glass fuse ,fairly short and looks something like a auto fuse. SAFETY FIRST ---ENSURE THAT THE POWER LEAD IS DISCONNECTED FROM THE WALL OUTLET BEFORE REMOVING THE BACK PANEL The fuse will be on the power wires before the transformer.
Nov 22, 2013 | Cars & Trucks
Fuse blows when plugged in
I assume it's the fuse in the TV that blows. You more than likely have a bad or shorted low voltage power supply. Probably not worth fixing with the cost of parts & labor.
Oct 06, 2012 | Televison & Video
Fuse # 4 2002 f 150
Stop plugging into the console power point with whatever it is that you keep plugging in that is blowing the fuse. The truck is not the CAUSE of the problem. Your defective accessory is. (cell phone charger, radar detector, GPS unit...whatever it is...?)
May 12, 2012 | Ford Cars & Trucks
Tv will not come no timer lite blinks
Things You'll Need:
  • Electrical outlet
  • Fuses
  1. Check that the power cord is securely plugged into the power outlet.
  2. Make sure that the power outlet is receiving electricity by plugging a different device into the plug and turning the power on. If the other device does not work you likely have a blown fuse or tripped circuit breaker.
  3. Replace the blown fuse or reset the circuit breaker as needed. If it happens again, an electrician should assess the problem.
  4. Contact akai Support if Steps 1 to 3 do not solve your problem. Only a trained service technician should attempt to fix the power problem with your television
Jan 22, 2011 | Akai PT46DL10 46" HDTV-Ready Television
I came home one evening and my system was off. I tried plugging it into different outlets and still received no power to my system. What could be the problem and how can I fix it?
hello, see if theres a power save buttton on the unit if not check the fuse in the plug if ok then the fuse inside the unit may blown. it may be glass type fuse it will be in the power supply if you can't see 1 then there may be a soldered in fuse called a wickman fuse fingers crossed
regards
shaun
Nov 27, 2010 | RCA RS2656 Shelf System
No power when i plug in a code scanner
Hello Chet.
It's possible that you could have a blown fuse.
The power supply to the data connector is also on the same fuse as the cigarette lighter/power plug.
The fuse is in the #13 slot in the underhood fuse panel.
Hope this fixes you up!
Nov 27, 2009 | 2006 Buick Rainier
2000 Buick Century lighter fuse blows when TomTom plugged in.
this is the cigar lighter receptacle causing the problem, take my word on this.
Aug 17, 2009 | 2000 Buick Century
No power coming from power accessory plus
you must have a blown fuse look on the fuse cover if it has one and also check the realy and fuse panel under hood PLS tak time to rate this solution
Feb 17, 2009 | 2007 Suzuki XL-7
Canon PC1061 Copier Logo
old marine
old marine
