Question about Canon imageCLASS MF4270 All-In-One Laser Printer
USB connection not being recognized on Imageclass MF4270 all of a
When the device is connected to my 2 Dell laptops or my dell desktop (XPS 210) the error states: One of the USB devices attached to this computer has malfunctioned, and Windows does not recognize it."
Is the USB port on the MF4270 shot?
  • maggsises Oct 26, 2009
    I appear to have come across this same problem with my Canon printer. I researched for a problem for some time now and tried many things without success. The printer was working fine until one day it was unplugged. When it was plugged in again (the same slot) it stopped working. I am also running XP with SP3.
    Things I have tried:
    Uninstalling and re-installing drivers.
    Updating drivers.
    Restarting PC
    Turning off printer, then on.
    Uninstalling and re-installing USB drivers
    New USB lead.
    All with the same problem with the PC stating "USB device not recognized." when the printer is turned on. Since this I have purchased a new PC. The printer worked and installed the fist time. But then the same problem appeared again and would not work. Assuming I had a faulty printer I purchased a new Canon IP4700. I attempted to install this on the new PC as per instruction without luck and the PC not recognising the new printer. I restarted the PC and miraculously it recognised and installed it. The next day after the pc was restarted, the printer was lost again and states the same problem of "USB device not recognised.
    Both PC's are running SP3 with all updates uploaded from microsoft. In my research I am finding this problem across the board and it the thing I have tried above are the common suggestions for a fix which have not worked. From this I can only conclude there is no fix for this yet and there is a glitch in XP with recognising some devices and there is no fix yet which I can find anywhere. I am all up for suggestion but I have tried all I have found over the past 3 months or so without any success. I now have a brand new printer which I can't use due to this problem.
    Sorry to carry on, but just letting you know ahead of time that many suggestions you might get may be unsuccessful.
    President:
  • 1,653 Answers
First make sure that the USB cable is OK and use another if you have one. Then make sure that the laptops have working USB ports from Device Manager. If they are OK then try powering up the Canon again without the USB cable connected to see if any errors are reported and then plug it in to your laptop to see if it is recognised. Check the status of the Canon Print Driver settings. If this all fails then you may have defective USB ports on the Canon and will need to get them repaired.
Posted on Oct 06, 2009
Dell xps 410 recognize hdmi
Could be an issues with your adapter. What resolution are you trying to send to the projector? Try lowering your resolution.
Also, are the proper video drivers loaded on your machine?
Oct 18, 2012 | Dell XPS 410 PC Desktop
Test dell xps 210 power
You need a power supply tester provided by DELL.
Aug 25, 2012 | Dell XPS 210 PC Desktop
Most laptop power supplies are made for a particular brand, so the best way to test is in another Dell laptop. The other way is using a voltimeter, first testing the power cord alone, and then testing the tiny connector.
Speakers not detected on Dell XPS 210 with windows 7
hmmmmmmmmmmm sounds like dell has an o/s discrepancy(no duoooooooooooeiiiiiiiillllllll)
it's the sound card drivers at fault
look at your device manager
start
control panel
system icon
and see who makes that sound card/driver
go to that website and see if they have the w7 version
don't get your hopes up
May 28, 2012 | Dell My XPS 210 (dxcwpf1_7) Intel Core2...
Connect midi to dell xps 420
You can use Midi to USB adapters.
Here: .MIDI Interfaces
Feb 06, 2012 | Dell XPS 420 PC Desktop
Hi i need drivers for windows 7 for my desktop dell xps 210
If you click here it will give you the choice of drivers and software to pick from.
May 27, 2011 | Dell XPS 210 PC Desktop
In my dell xps L501x ethernet cable is shown unplugeed even when it's plugged in. The cable which i m using works fine on my desktop which i connect to my adsl2+ mt882 modem through this cable. Cable also...
1. laptops USB port is not recognized by the router .
2. This could be due to the usb hub drivers for this unit not being installed on the laptop.
3. check your "device manager" to see if you have all the usb hub driver installed.
4. Also check your router manual for the usb setup for a laptop connection.
Feb 20, 2011 | Skque Ethernet Cable Cat5e RJ45 White 30...
Using Wii with our XPS One
you will need a like port on both device,look at the output ports on the wii and the (eg usb or firewire) input ports on the computer.If you find s port and and cable it should work.Look also at the documentation that came with the wii.
good luck
Oct 02, 2009 | Dell XPS One Desktop PC RED-20" HD...
Wireless issues with my Dell XPS/Dimension One desktop
Even if it's a new Dell, you may need to update either the drivers for the wireless card or the BIOS.
Also, verify which protocol your Dell is set to use (i.e. 802.11g, 802.11b, auto-select, etc.). Dell may have fixed to to a slower protocol for compatibility.
May 02, 2009 | Dell XPS One Desktop
Canon imageCLASS MF4270 All-In-One Laser Printer Logo
539 people viewed this question
old marine
old marine
