Question about Maytag Neptune MAH5500B Front Load Washer
Maytag 7500 Water in cups for bleach & softener
Maytag 7500 It has this plastic thing that I supposed to put the bleach and softner in separeteley. I can lift the tray - cup out and wash it. I noticed after a load the cups are full of clean water. Is this okay? I just got the washer.
    President:
  • 1,304 Answers
You should have a small amount of water in the resivoir this is part of the siphon system
but you do want to keep it clean every 4-5 loads put it through the dish washer
Posted on Oct 06, 2009
Testimonial: "Thanks for an answer. You are the only that knew what to do."
To use liquid detergent does the machine have to come with cup
ROFLMHO Thuli the lid /cap of the detergent bottle is your measure.and yes you just pour it into the water as you would use powder .bleach and fabric softeners are the only thing to keep seperate
May 26, 2015 | Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have an older Maytag washer without a user manual and was wondering if the cup in the top of the agitator was for adding fabric softener? If it is when do I add it and how much do I add? The model number...
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-A9200/3048/0153200/X2900731/00005?blt=06&prst=&shdMod= I thinking you are referring to item 7 which is listed as a dispensing cup. If I remember right it just sits on the agitator as a means to take off and use to measure soap, fabric softener. Since there is not a water flush line to it, I wouldn't use it to try to dispense the fabric softner. But it probably would do any harm to try it and see how much was actually left in the cup.
Jun 21, 2011 | Washing Machines
Hello sir,i have a kenmore series 90 washer & dryer.this specific machine has top dispensing detergent/bleach&softner.when it becomes time for the softner to be dispensed on the re-fill the machine...
PLease check the hose that goes from the INLET VALVE to the dispensing system cup on your washer. This hose probably has a hole or the plastic dispensor is cracked and therefore leaking.
The inlet valve is working and when the time comes the water goes to the dispensing cup, so the system is working it is just the hose, dispensing cup or both.
Nov 19, 2009 | Kenmore Washing Machines
Maytag MAH8700AWW will not dispense fabric softener
u need to replace the water valve theres 2 the cold is what u would replace
May 21, 2009 | Maytag MAH8700AWM Neptune Front Load...
MAH8700AWW - No Fabric Softener
Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
Focus on pages 15 thru 25. Hope this helps you.
http://www.servicematters.com/maytag_library/docs/16026126.pdf
Jan 26, 2009 | Maytag MAH6500 Neptune Front Loading...
Bosh washer won't dispense softener. cleaned the tray and tested it by filling with water and it drained completly out, so i know its not clogged. washed another load and softener still there at end of...
I had the same problem. the only thing that works for me is fulling the fabric softener compartment all the way to the top with water then it will syphon down! it adds it to the load at the start instead on the rinse cycle but its better then nothing!
Jul 28, 2008 | Bosch Washing Machines
Washer leaves fabric softner stain on white clothes
Dispenser wholes are probably clogged and all the softener is not dumping when it is supposed to!. Top loaders usually have a little cup like place to add the softener in the top of the agitator!
Those the Manuel tells you to rinse with water occasionally!
If you can't figure it out, call service and get it done and over!
You will feel better!!!
These guys are good
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Jul 28, 2008 | Maytag Performa PAV2200
Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
Jun 13, 2008 | GE WSXH208A Front Load Washer
Fabric Softener doesn't empty
My husband just fixed ours after not seeing a solution on any other site. He pulled out the dispensing unit and pulled off the blue plastic piece on the top of the fabric softener and bleaching section. He then ran warm/hot water (not boiling hot) through the holes where the fabric softener is suppose to flow through. This cleaned out excess fabric softener that had coagulated in the elbow and blocked the flow of softener to the unit.
Feb 14, 2007 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
82 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
