1. Start > Run. 2. regedit 3. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class in the Registry Editor dialog box and select the {4D36E965-E325-11CE-BFC1-08002BE10318} key, which appears as a folder. 4. Select File > Export 5. save the file to the Desktop in case you need to restore it 6. In the right panel of the Registry Editor, select the LowerFilters line, and then choose Edit > Delete. Click Yes in the Confirm Key Delete dialog box. 7. Do the same for the UpperFilters line 8. Close the Registry Editor. 9. Restart Windows.
1.Make sure the CD's or DVD's u are using does not have scratches on it.
2.IF CD's are fine then Probably your CD Drives Lens is not working properly.Get your Lens repaired.And I am sure it would work.
won,t let me download any thing put a cd in the e-drive an it says that i don,t have an e drive at...
(More)
won,t let me download any thing put a cd in the e-drive an it says that i don,t have an e drive at all which I KNOW THAT I DO
I was burning some CD's, i was onto the 8th disk when it just wouldn't detect the end of the burn or...
(More)
I was burning some CD's, i was onto the 8th disk when it just wouldn't detect the end of the burn or eject the CD. I shutdown and re-started and still nothing was being detected. I force ejected the cd and tried another but still nothing seems to be detected. Any help appreciated, laptop is an Acer 3623.
i have aspire 4720z laptop in my drive can't open Cd's i use XP it will not open any cd's like...
(More)
i have aspire 4720z laptop in my drive can't open Cd's i use XP it will not open any cd's like mother board cd's also please give desired solution for this Thanking You Harikrishna
My Acer laptop CD- Rom doesn't work at all. The light doesn't even flicker nor the door open. I went...
(More)
My Acer laptop CD- Rom doesn't work at all. The light doesn't even flicker nor the door open. I went into the device manager and the device status is properly working but its not! I can use a pin to open the door but it will not acknowledge that a cd is in the drive. It tells me to insert a cd.
