Question about Whirlpool Duet GHW9150P Front Load Washer
Squeze clamp i took the squeze clamp off and cant get it back on
  • meyers1999 Oct 06, 2009
    that would work and keep it sealed right. were having problems with the f21 error... trying everything repair guy due in 3 hours hoping to be able to cancel they want to put a new pump in
  • yadayada
    yadayada May 11, 2010
    go to the store and buy a conventional band clamp, problem solved?
    Top Expert:
  • Whirlpool Master
  • 76,682 Answers
Yes it will seal right, but doubt iot will correct fault code
Posted on Oct 06, 2009
Why does my bobbin thread tangle around my bobbin plate
try changing the needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
try rethreading the machine top
Jun 10, 2012 | Brother Sewing Machines
How to use cv joint clamping pliers
you will install the clamp and then put the pleirs over the clamping edge and squeze the pliers to tighten the clamp, if the clamp is an adjustable clamp you would tighten the adjustment as far as it will go then clamp it,heres a picture to show you where to put the pliers jaws. good dayjohnjohn2_136.jpg
Sep 04, 2011 | Kia Sephia Cars & Trucks
Wasflashing f21 my huband took the pump filter out and it was full of stuff he then took a clamp off of a bigger hose and found a ball in the...is it supposed to be there....now he cant get the clamp back...
Hi, the ball is a "check valve" device that is necessary. It is a type of one way valve. Getting the clamp back on is difficult but it can be done. If he is having difficulty improvising my hat is off to him.
Those clamps are difficult to work with. There is a Specific tool for removing and installing clamps on a washing machine. It is called a "hose clamp pliers"
Here is a link
http://www.google.com/products/catalog?num=100&hl=en&lr=&newwindow=1&safe=off&q=hose+clamp+pliers&um=1&ie=UTF-8&cid=1315315859135749155&ei=lPAjTeDHEYOBlAevp8S3DA&sa=X&oi=product_catalog_result&ct=result&resnum=2&ved=0CCwQ8wIwAQ#
Hope this helps,
Mark
Jan 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Im doing my back brakes on my 2002 golf tdi. i have the caliper off. i was trying to put my C clamp on it and push it back so i can make room for the new pads and rotor. But Im hitting resisitance. It...
The brakes have an automatic emergency brake adjustment and because of this a special technique is required to get the piston pushed back in. Hopefully you didn't force it and damage it. You can also buy a special tool that will do the job but you can also use a C-clamp and a pair of channel lock pliers. Put the C-clamp on and put a little bit of pressure on the piston. With the channel locks grab the metal edge of the piston and twist it (can't remember the direction but it will be apparent when you do this) until the C-clamp loosens up a bit. Adjust the C-clamp to put some pressure on the piston again and twist the piston again. This will slowly work the piston back to where you can install the new pads. Be careful not to pinch the rubber boot when you are grabbing the piston edge with the pliers.
Oct 11, 2010 | 2002 Volkswagen Jetta TDI
REPLACE REAR BRAKE SHOES ON 199 NISSAN ALTIMA
Have you tried a big c clamp and squezing it that way also try to loosen the emergency brake tensioner its in the back part of the brake assembly use a flat head to loosen it
Oct 28, 2009 | 2001 Nissan Altima
My calipers wouldnt compress so i took them off now they wont go back on..help
BRAKES are one of the things you dont play with as your life and other peoples depend on them being done correctly, but concidering that you have got them off and carnt get them back on-------- take off the top of brake tank then take out the pads (1 side at a time)now compress the piston with a G clamp back as far as it goes ,then refit pads and refit
caliper and tighten up tight and then pump pedal 3 times and now turn the disc it should be a bit tight to start with.
THE other side take out 1 pad and retract the piston back to the stop ,put in new pad and then the other one .do the same pump the pedal and recheck the rotor for turning refit brake tank lid.
Road test burn them in a bit before rechecking disc for free spinning
Oct 13, 2009 | 2005 Mazda 3
Took bar out of clamp and would not go back in. took it apart and everything fell out. need illustration of clamp working parts to put it back together.
GOOGLE! enter the make and model of your product followed by the words "instructions" and you should be able to get some results. If you can't find any feedback, try different variations like "assembly illustration".
Aug 04, 2009 | Hand Tools
91 kx 250 tight clutch
are you shure you have ALL the clutch plates?? the cable is well lubed? the pushrodbearing/adjuster may be in the middle of the clutch basket cover plate. OR you have the wrong springs installed!
Jan 23, 2009 | kawasaki KX 250 Motorcycles
91 kx 250 clutch too tight
hi m8,, wen u put spring bolts and springs on,, u must do them right up ,, untill the spring is completly comprest,, ,untill the spring bolt wont do up any more,,cheers
Our front load washer will fill and drain, but won't spin
I need a solution for this problem, you can help me, please
Nov 24, 2008 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
16 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
