Question about Sewing Machines
The tread gets all bunched up on the underside of
The thread gets all bunched up on the underside of the material. I tried rewinding the bobbin and changing the needle. I probably just bumped a lever or dial the wrong way, but I am not sure. this happened in the middle of sewing a seam.
  • Maria Jolley Oct 08, 2009
    It is still catching on the bobbin holder underneath and bunching up. Are you sure about tension dial at "5"?
    Novelist:
  • 152 Answers
Take the thread off the top of your machine and rethread it. Anytime a sewing machine bunches up the thread on the bottom the cause is the top thread. Make sure the tension dial is on "5". After you thread the machine, put the pressure foot down,(like its resting on fabric, but not on the thread), and pull the thread towards the back of the machine. It should be somewhat tight. The needle should "bow" slightly before the thread comes through the needle.
Posted on Oct 06, 2009
  • Norm Himebaugh Oct 08, 2009
    Did you do the "Pull Test" I described in my first posting? Ex. The needle should bow backwards slightly before the thread comes through it, does it? Did you also take the thread off the top of the machine and rethread it?
  • Sewing Machines Master
  • 1,388 Answers
For a comprehensive 5 page illustrated tutorial...Check this solution:
http://www.fixya.com/marketplace/servicepage.aspx?srvid=17197&ctgid=164&brdid=1060&prdid=131120&smid=23884&mthid=1&mpsaugid=347d7805-9ce5-42d2-b812-b602b6cf7437
Posted on Oct 18, 2011
    Problem Solver:
  • 4 Answers
Thread will ALWAYS bunch if the needle is blunt. even if unsure put in a fresh one in and make sure you have the correct thread for fabrics.
Posted on Oct 21, 2009
My machine bunches tread on the bottom of the fabric when sewing. What am I doing wrong. This machine is new to me.
thread bunching under material is an indication that the needle thread is not at the correct tension
tighten up the tension setting until the result is where the both treads meet at the center of the materials being sewn
practice on pieces of scrap until you get it right
Oct 01, 2015 | Sewing Machines
Model 2200 EC1 SERIES The top thread Bunches and tangles on the underside of the sewn material. I have checked that the upper thread tensioner is in good order. When I observe the thread in the shuttle...
try these suggestions
1.check to see if your needle is bent-place needle on flat surface & see if it rolls good
2.if needle make poping sound when going thru fabric it is blunt
3.check to make sure the bobbin is not warped
4.make sure there no loose thread or lint in bobbin area
5.make sure there are no burrs on bobbin or bobbin case
6.check to make the thread does not come off the thread take-up lever
Aug 23, 2010 | Toyota Sewing Machines
Bunching and Looping (Bobbin Side)
Thread the machine with different color thread for the needle and the bobbin, then see which color is bunching up.Ill bet it is the top thread.
Jun 16, 2010 | Brother CS6000i Computerized Sewing...
When I try to use the embrodiery unit the thread bunches up on the underside of the material--it is very loose. Any ideas on what is wrong?
The tension on the bobbin (under the deck) needs to be right. When you load the bobbin, try and pull out the thread a little. It should be firm. You should have to pull a bit to get thread out. If not, the tensioner on the bobbin is set wrong or has backed off (Or you loaded the bobbin wrong) Don't use the bypass slot!
There is one screw on the side of the bobbin holder, where the thread is pulled through when you load the bobbin. This screw can be adjusted to control the tension. See pfaff page on bobbins
Apr 21, 2010 | PfaFF Creative 7570
Cotton keeps getting knotted from the bobbin
upper tension is wrong or upper threading is wrong (problem is always on the other side of the bunched thread)
Jul 07, 2009 | Janome Sewing Machines
Bobbin holder doesn't spin
Be really sure that the thread is threaded properly. Correct size needle for the material, and no cheaper thread. It does make a difference.
Aug 22, 2017 | White Sewing Mighty Mender WW100...
Help problems with Bobbin and tread
I found that if the bobbin is not threaded correctly or if the upper thread is not adjusted properly, it will bunch on the bottom. Also, if the stabilizer is not firm enough for the material it will bunch.
Oct 11, 2008 | Husqvarna Viking 1
Won't sew
you have tread in the bottom of it. and needs a cleaning. check the tension, most set on 3
Dec 15, 2007 | Kenmore 12102
Thread bunching
I discovered that when the thread is knotting up on the underside of the material that it is usually the threading on top and has nothing to do with the bobbin.
Jun 29, 2007 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
798 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
