Matag washer won't let water in tub. model#a8240
  • yadayada
    yadayada May 11, 2010
    both hot and cold?
  • 136 Answers
Check the hose screens where your hoses screw on to your hot and cold water valves
Posted on Oct 07, 2009
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
GE Spacemaker Washer/Dryer. Model # DDPI380GAMWH. Water won't stop filling. It continues to fill during all cycles. Fills during agitation. Agitates inproperly. It agitates in short pulses as water...
Thanks for choosing FixYa and welcome. This sounds like a problem with the water level switch in the washer. It controls the amount of water entering the tub. It is probably defective. You may want tomake sure the switch is getting power first by testing the wires with a voltage meter.
Jun 18, 2011 | Washing Machines
Matag model mav7757aww it has a glitch in cycle
check pump and drain hose for blockage
Aug 16, 2009 | Washing Machines
Washer mod.mav8551aww wables very mush
Check load distribution, spring and struts first.
If it is nothing in there , then it is usually a drum bearing or drum bearing spider problem.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 28, 2009 | Maytag Washing Machines
Matag washer may be leaking, esp when in use.
Remove the front panel from the washer. Fill the tub with water and then set it for spin.
Look for water coming from the machine. If so, report back as to where the water is coming from.
If no water is coming from the machine......
While the water is pumping out, look at the drain line in the wall and see if it backs up.
If so, call a plumber to clean your drain lines.
Mar 04, 2009 | Maytag Washing Machines
Matag top load washer model # LAT9604AAE filled but no agitation
If just getting the water out is your main goal, this can be accomplished using a shop vacuum.
Be sure to unplug the power cord before attempting any repair! Another way to drain a machine is to use a bucket. Put the discharge end of the drain hose from the washer into the bucket, making sure the hose end is higher than the level of the water in the washer, and slowly lower the hose and bucket until the water flows into the bucket. Raise the bucket and hose end back up above the level in the machine tub to stop the flow. Repeat until the machine is empty.
Give the machine a try after removing some of the water as you may have tripped a limit switch and the unit may just be overfilled
Dec 29, 2008 | Maytag PAV2300 Top Load Washer
Washer tub goes off balance every time and washer walks!
there may be a possibility here of the centre hub being worn or the liner tub bearing being worn due to the age of the machine.. here is a list and diagrams of the parts you may need and can get from here:-
http://www.easyapplianceparts.com/MultiModels.aspx?ModelNum=mat13mn&searchTerm=img_CW17-6&RefineSearch=0&imgMfg=Maytag
try to check for slackness when the tub is empty causing a rocking/slapping motion whilst empty. if the tub is used regularly and to its maximum capacity then the likeliehood is these bearings/hubs may need to be replaced.. the "walking" across the floor will be accented by the amount of items plus water in the tub. and if the tub is off balance,then this will be more highlighted when also full of water and items... if you feel this is over the top,then try to lighten the load that is in the tub at any given time. this will determine weather the bearing has indeed worn .the lighter the load,the less "walking the machine should do in cycle.. the only time walking would be unchanged is during the spin cycle,when the speed is of a constant one and it will vibrate at the same rate. placing it on a rubber mat is not a solution but just something that will make you hopefully think it is solved
and you may as well just bolt the machine to the floor and hope for the best
Mar 31, 2008 | Maytag MAT13MN Top Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
