Question about Kenmore Washing Machines
Kenmore 70 series washer will not spin with load but spin without load. also found oil on floor under washer. what's my problem/
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
First, I'd check the motor coupler that transmits power between the motor and transmission. If the coupler is bad, (the prongs are broken) it might be able to transmit enough power for agitating but slips when thr washer goes into spin mode.
Following are descriptions of how to remove the cabinet and get to the coupler.
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If you pull the transmission you should be able to see if it is leaking.
See the following Whirlpool parts breakdown for top load, direct drive commercial washers (consumer models are basically the same.)
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
I'd look at the gearcase cover seal for a possible leaking problem.
Posted on Oct 06, 2009
Kenmore 70 series washer will agitate but will not spin
First,I'd check the motor coupler that transmits power between the motor andtransmission. If the coupler is bad, (the prongs are broken) it mightbe able to transmit enough power for agitating but slips when thrwasher goes into spin mode.
Seethe following Whirlpool parts breakdown for top load, direct drivecommercial washers (consumer models are basically the same.)
Oct 06, 2009 | Kenmore 22422 Top Load Washer
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Mar 27, 2009 | Kenmore 22422 Top Load Washer
Why My Kenmore 70 Series Washer Won't Drain Or Spin?
You need to replace the lid switch. This is located under the case. you have to take the case off to change this part. This is done by taking the 2 screws out of the front of the control panel. Then flip the panel back and remove the 2 brass clips that hold on the case. Then you can remove the whole washer case to get acces to the lid switch. This is a very common problem and an easy problem to fix.
Feb 13, 2009 | Kenmore 24932 Top Load Washer
Series 70 Kenmore will not spin on any cycle.
Since the washer would still pump out the water, I removed the cover, then the pump, then the motor and I then found the coupler was broken.
Jan 09, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series washer will not spin, clothes are too wet
Not a belt, this is only a sound deadening devise on the brake housing. Not really needed. Replace the coupler
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series top load washer - no spin
the older belt drive washer has a cylanoid under it on the top trans missin called a wig wag eather broken wire to it are bad wig wag can still be found ck lid switch also
Mar 19, 2008 | Washing Machines
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Washing Machines Logo
66 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
