Question about iLO (2 GB) MP3 Player
My busbi 2gb usb key is write protected and will not let me delete files off it
5 Suggested Answers
  • 700 Answers
SOURCE: how to remove write protect on my usb flash drive
Maybe you are infected with a virus. Run CMD on rrun command or get to run the Windows Dos Prompt. Goto flash drive drive letter. Then type DIR/AH, this will show you list of hidden files in your flash drive usually if you get an autorun.inf you are infected with a virus. Type TYPE AUTORUN.INF with the space in between.This will show you the script if it will run an exe command usually untrusted one. Usually the autorun.inf and the linked exe is attributed to be hidden, system, and read only.
If the files in your flash drive is not so important you can try to delete the autorun.inf only. But you will gonna do this first. In its drive letter type ATTRIB -H -R -S AUTORUN.INF hit enter. Then type DEL AUTORUN.INF. trying to access the flash drive in windows screen you can get that something is cannot be found. But you could actually delete and load files into it. Or try to access the drive rightclicking it then select EXPLORE.
Hope this help. Post comments if this does not help.
Posted on Jun 03, 2009
SOURCE: how to remove write protection from usb device
i have genx 4 gb usb 2.0 how can i format this drive...i will try for formating but showing write protect message,,,
please give me the solution
from bijoy dubai
Posted on Jul 28, 2009
  • 11 Answers
SOURCE: MY USB DOSN'T ACCEPTS FILES OR DELETE THEM. the
you will to call the company or buy a brand new usb cord
Posted on Nov 10, 2009
sunil06
  • 394 Answers
SOURCE: I cannot delete or copy any files onto my usb
format it completely
Posted on Jun 04, 2010
My usb cant save a file anD delate a file because of a write protected? A BRAND OF KINGSTON
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
don
Feb 24, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I am trying to get some photos off an old computer running Windows 98. I have no CD burner only a couple of USB slots in the back. However when I put a USB Key in the back it does not recognise the key. I...
Ok the file system on windows 98 is called FAT, the file system on newer cmputers is called NTFS, It is forward compatibility but not backword. You need to put in a USB flash Drive also called a thumb drive or stick drive into the win98 machine and check for harware changes using these suggestion.
1. insert the flash drive into usb port
2. right click on "My Computer" > Manage - The Computer Management window popsup.
3. Select Disk Management
4. Locate your Flash Drive at the bottom where it starts with "Disk 0" which is your Hard Drive.
5. Your Flash Drive should say something like "Disk 1, removable", to the right it should have a blue line which means it's a primary partition.
6. If it has a Black line, then it means that the Flash Drive has not been partitioned. To fix this do this:
7. Right click on the black line. It should give you an option to partion it.
8. Go ahead and partition it to FAT or NTFS which ever option you can get or want.
9. Once it is finished, then you will be able to read and write from the Flash Drive.
Let me know if it does not work or if you are having problems.
Jan 01, 2011 | Computers & Internet
I CAN NOT DELETE THE FILE, WHY? USB SAID REMOVE WRITE PROTECT. HOW TO REMOVE THE WRITE PROTECTED?
open the file try deleting all the other files around the specific file first
hope this helps
Aug 12, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to remove the write-protection in my FLASH DRIVE?
  1. Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "use device" or "driverdesc" to open usb mass storage device. right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
  2. Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
Jun 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
HOW TO FORMAT A WRITE PROTECT USB DRIVE
First Option:
Explore your USB drive using Nero 6.0 Burning ROM Software.. This shows all hidden files in USB Drive.. Try to delete all files manually through nero 6.0 itself. if you fails, USB is Damaged.
Open your USB Drive in Linux OS.. (Fedora 9.0 and Above is most recommended).. Delete all files manually.. thats all
May 29, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How do you remove write protect from a busbi 2gb flash drive. only used once to backup daughters comp. now can't copy files or delete or even reformat. theres no write protect button that i can see. help
There should be a small slide somewhere on the drive. It could be black, yellow or any other color. Or it could be just a button, depending on your specific model. Slide it to the opposite side and try again
Mar 15, 2010 | Computers & Internet
Can't delete some data already installed in Kingston pendrive?
What type of files are they (be more generic if files are personal and/or name the extension names of each files that cannot be deleted)
Solution:
- Try changing the name of the files and then deleting them
- Is your USB Password Protected ~ this may stop you from deleting those files (try deleting the Security on your USB)
- System Deletion Performance may be slow and.or unknown Deletion Command
Hope I helped
- donman92
Jun 01, 2009 | Computers & Internet
How can I delete write-protected files in pen drive
my multi-card (SD) kingston 2 GB is unable to copy , delete and format. It is always say that your multi-card is write-protect. I try to delete some file on it. It is able to delete but i reconnect to my PC,it shows my previous deleting files. why? If you have time , help me please.
Aug 07, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
iLO (2 GB) MP3 Player Logo
315 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
