I need a wiring diagram for a goodman AEPF313716 3ton air handler I have installed one in my home and I am having a low voltage problem with the unit . It is a split sys . The comp. unit (outside) is a GSZ130361/a
  • 80 Answers
Not sure if this helps>> Goodman
Posted on Oct 06, 2009
Testimonial: " great !!!!!!!!!!11"
What cause 3 amp fuse to keep blowing when power in turn on goodman air handler
The 3 amp fuse is in the red low voltage (24 volt) thermostat wire
and only gets power when the thermostat is set to turn on heat or a/c It should be connected to the red wire from the thermostat
Nov 13, 2014 | Goodman Manufacturing Goodman ARUF48D14...
HE heat pump won't talk with old air handler?
The fact is, the air handler supplies the voltage, blower, and electric heat. In order for the heat pump to work correctly, the wiring from the thermostat and heat pump need to be hooked up right to the air handler. The thermostat is what tells which component to come on. If the fan stops, but the condenser keeps going, you either have a faulty fan relay on the air handler, faulty thermostat or wiring, faulty wiring at the heat pump, or the contacts on the new unit are sticking, which is highly doubtful considering it is working now. I hope I have helped you understand this a little more. Good luck and don't let them push you around, get someone that knows what they are looking at.
Jul 18, 2012 | Goodman Heating & Cooling
I have a goodman ac unit in my apartment complex that is blowing 5 amp fuses in the air handler.
The low voltage wire to the out side is shorted somewhere or the contactor coil is burnt.Thats all it could be one or the other.
Jan 05, 2011 | Heating & Cooling
My dog chewed the thermostat wire by the compressor, i replaced the chewed wire now the thermostat won't turn on, therefore; no ac.. could it have blown a fuse? if so, where are they?
Either you have blown the low voltage fuse located inside the air handler (if there is one) or you have blown the transformer feeding the low voltage control wiring.
If the transformer is blown due to no fuse installed, I would recommend installing a low voltage 3A fuse in line with the red terminal coming off the transformer. This will protect the transformer in the future.
Aug 01, 2010 | Goodman CKL42AR42 Air Conditioner
Problems with low voltage control wiring turning on cond. unit
Only 2 wires going outside.
Yellow from the thermostat and the common wire from the lv side of the transformer.
Apr 28, 2009 | Heating & Cooling
Goodman SSX16 split system not working
Defective thermostat wire.
Defective contactor.
With the t-stat set for cool and turned down on a low temperature, check for 24 volts at the contactor low voltage hookup. If you have 24 volts, replace the contactor.
You can manually close the contactor to make sure the high voltage is going through it.
Apr 28, 2009 | Goodman CKL60AR60 Air Conditioner
Wiring connection for a Ruud air handler & seeking its wiring diagram.
we are trying to install a goodman heat pump with a rheem air handler, the orange wire is hook up and the unit is still staying in the heat mood. does anyone have a wiring diagram for the air handler, their is some white wires in the air handler one with a purple strip and one with a black strip we need help
Jan 05, 2008 | Heating & Cooling
Heating & Cooling Logo
328 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
