Question about ViewSonic VA721 17" LCD Monitor
ViewSonic VA721 monitor
Screen black when on. If powered off/on screen will appear for a split second. Is this fixable? What could be the problem? Worth fixing?
  • 2 more comments
  • recr8 Dec 24, 2007
    Thank you so much for your reply. I bet you are right - it's just so annoying to be able to see the screen for a split second..then nothing. Gr-r-r. We certainly live in disposable times so shopping I will go. Thanks again for your information.
  • jkmontana Mar 15, 2008
    My viewsonic is only about 2 years old.  The left side of the screen is almost black with slightly lighter as it goes to the right.  But this is pretty grey and almost unreadable.  It tends to get a little better as it warms up but is hard to read even if you leave it on for days.  It does have a screen saver so the same image is not left on forever.  Any ideas?  Got it at Fry's Electronics
    Jon
  • Anonymous Sep 07, 2008
    My screen is black when on. If powered off/on screen will appear for a split second. Is there something to do with a defective wire/coonection that is missing 2 of the 15pins? Is this fixable? Any solution? I have unpluged and tried connecting with a different cpu, seems the problem is with this same monitor.
  • Anonymous May 01, 2009
    Same problem.
  • 74 Answers
This is only an educated guess based on my years of computer and electrinics experiance. I believe the problem is the AC inverter that supplies current to the monitors back light,it powers up and fails. the monitor is working but without the back light you get a blank screen.The problem is fixable, but the delema is that for a technician to troubleshoot and repair the problem may cost as much as replacing the monitor since the prices have dropped so much in the last few years.
Posted on Dec 23, 2007
Hi! My Viewsonic VA721 LCD Color Monitor's screen is getting darker over time. I've had it for about 5 years. Is it just getting "old" and worn out or is there something I can do to correct...
It can be that the power supply is dying due to bad caps (or worn out backlight lamps) as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
It is old monitor so it may not be worth spending on it.
Please leave rating if it helps.
Feb 02, 2011 | ViewSonic VA721 17" LCD Monitor
The power light keeps cycling on and off. and the screen flickers on for a split second.
Look for bad caps, shorted transistors, etc. See my pictures here:
Please read my guide and learn about bad caps and look at the pictures of failed VIEWSONIC and all other brands of monitors.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 10, 2010 | ViewSonic VA721 17" LCD Monitor
I need a driver for my va721 monitor
ViewSonic VA721 VA721 Monitor Driver ... Login. Register ... Uninstall Windows drivers How to Uninstall Windows Drivers and why you need to know it ...www.nodevice.com/driver/VX500/get36507.html
Dec 06, 2009 | ViewSonic VA721 17" LCD Monitor
Viewsonic VA721 - Screen goes blank for second or two and returns
Sounds like its going to sllep too soon make sure you do not have it set in your video card settings. also try it on a diffrent computer. if that does not shore it up replace the acpi board
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 11, 2009 | ViewSonic VA721 17" LCD Monitor
Screen dialoge analoge and turns black i have no credit card then i dont know how to pay for asistance
I'm assuming turns black and blue then turns off? First make sure your connectors to your monitor and back of pc are secure. But it sounds like your video card needs to be reseated.
May 24, 2009 | ViewSonic VA721 17" LCD Monitor
Increasing resolution higher than 800x600
the screen res is adjusted through windows not through the monitor.the pop up you speak of is only informing you the current screen res as set up through windows.
Dec 15, 2007 | ViewSonic VA721 17" LCD Monitor
ViewSonic VA721 17" LCD Monitor Logo
284 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
