Question about Garmin Quest 2 GPS Receiver
Quest 2 antenna contacts cleaning???
I own a Quest 2 and have had periods where I am unable to find satellites with a clear overhead sky. I feel sure it is in the antenna contacts but have not been able to remove the antenna to clean it. How does the antenna come off?
  • 24 Answers
You will need a small phillips head screwdriver. Turn the GPS unit over on its face with the back and flip up antenna facing you. There are 6 screws on the back holding the two halves of the GPS together. With the Quest oriented so the hinge of the antenna is away from you, carefully remove the two phillips screws on the right hand side of the back of the unit. This holds an endcap of the unit and the flip up antenna in place. Be VERY careful in removing this, as the antenna has a small spring putting tension on it and this spring will easily pop out and get lost. The antenna should easily come out at this point. If you look carefully, on the left side of the antenna, you will see the swivel for the connection. There is a spray called DeOxit used by radio repair people that does an excellent job of cleaning contacts. If that is not available, use a Q-tip and some isopropyl alcohol and gently clean the contact areas of the antenna and where it plugs in on the chassis. Allow the alcohol to dry or gently blow it out with air. Reassemble, (don't forget the spring), and it should work just fine.
Posted on Jan 23, 2010
Antenna message all the time
If you are not in a building, or between high buildings, and the GPS device still has antenna problems, you have to assume the device is defect. But most of the time, when the device has no clear path to the satellites, from where it should get its signals, it will say antenna signal missing (or something like that.
When you are sure the device has a clear view to the sky for more than 2 minutes and it still is in trouble, assume the antenna or the receiver is defect. Goto a repair shop, or buy a new one.
Jul 26, 2014 | Magellan RoadMate GPS
Issue with gps not working cant get it to work
Most issues with GPS devices relate back to the lack of a clear view of the southern sky (for those located above the equator or a northern sky for those below the equator). if you are in an open area, and still unable to get it to work properly - read on.
If this is a new installation, review and carefully check your work. Make sure all connections are made up properly and tight. Check the manual to make sure you're using the product the way it is intended.
Check your antenna. A poorly connected, damaged, obscured or missing antenna will prevent the GPS from obtaining a "fix". The antenna should have an unobstructed view of the sky. If still unable to get it to work, contact BOSS directly via their webpage here.
Oct 25, 2013 | BOSS AUDIO SYSTEMS Car Audio & Video
Why my location is always in chicago IL i'm in hawaii n i'll use in hawaii Also I can get signal at all...... I just purchased from sam's club. help me.
As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.If your unit has not been used for an extended period of time (more than a month), it may take 3-5 minutes to acquire satellites.If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.*Note: Some units may not be compatible with an external antenna. Please check the Compatible Devices tab on the external antenna's page to see if your unit is listed. OR I set up this link that will take you to ensure that it has the latest version of operating software http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Sep 11, 2011 | Garmin nuvi 1490T GPS Receiver
I have a Garmin Nuvi 300 model and from last few days its not picking the satellite signals when I open the antenna, it keeps saying searching for satellitie signal. What could be problem & can it be...
Hello there,
If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes. If your unit has not been used for an extended period of time (more than a month), it may take 3-5 minutes to acquire satellites. If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal. If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased. If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions. If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites. If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*. If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
Hope this was helpful to you. Goodluck Elect_Comp
Sep 01, 2011 | Garmin GPS
I have a garmin 260 and lately when I turn it on it takes a very long time to acquire satelites.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
*Note: Some units may not be compatible with an external antenna. Please check the Products tab on the external antenna's page to see if your unit is listed.
Jan 16, 2010 | Garmin nuvi 260W GPS Receiver
Slow on picking up satelite on nuvi 260w
Good Luck. Did this help?
Dec 03, 2009 | Garmin nuvi 205W GPS Receiver
While driving Garmin Nuvi 250 constantly loses satellite signal. The screen says that it is aquiring a signal. It is also constantly refiguring the route.
Nov 12, 2009 | Garmin nuvi 250 GPS Receiver
Nuvi350 doesn't locate any satillites. What can I do?
Jul 11, 2009 | Garmin nuvi 260W GPS Receiver
Brought my NUVI from NY to San Francisco and it doesn't locate any satillites. What can I do?
Good Luck
Jul 07, 2009 | Garmin nuvi 260W GPS Receiver
No satillite reception
1. It takes a long time to auto-locate from a cold start. Are you leaving the unit outside with a clear view of the sky (no clouds, ideally) until it fails to find the satellites?
2. Be sure that the rotating antenna is attached properly. I suggest detaching the antenna, making sure that the contacts are clean and unobstructed, and then reattaching the antenna properly and securely.
3. Look up in the manual on how to "assist" the auto-locate mode by telling the unit your approximate location before you ask it to auto-locate for you.
Again, be sure you have the unit in a position where it has a clear, unobstructed view of the sky when you try this. That means not inside a building, not in a car, not under trees, etc...
Sep 09, 2007 | Garmin GPSMAP 276C GPS Receiver
Garmin Quest 2 GPS Receiver Logo
200 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
