Question about Aqua Vac Tiger Shark
No instruction book how to use and what detergent to use
  • 11,896 Answers
Copy and paste this link in your internet address bar in a new tab to bring you to your manual:
www.poolcenter.com/TigerShark_Manual.pdf
Posted on Oct 06, 2009
Whirlpool Duet coming up with these error codes FO8 and EO2
It says a common solution for this error (f8 e2) is:
The detergent drawer or detergent cartridge might be clogged with detergent. Clean out the detergent cartridge per Use and Care Instructions.
If cleaning the detergent cartridge did not correct the problem,
check spring is on lever top of dispenser have to remove top of washer
Dec 26, 2016 | Whirlpool Washing Machines
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
We have awhirlpool washing machine it calls for he detergent do we have to use he only?
Yes you do. Standard detergent will produce to many suds and also clog the dispenser sytem over time.
Feb 04, 2011 | Whirlpool Washing Machines
Too many suds even after running the rinse cycle while empty of any clothes
Some of these new top loaders require Frontloader detergent.I know F&P Aquasmart does.if you are useing Topload detergent it maybe over sudsing.Even though its a top loader some of them are ment to use Front load detergent..Fill with water & flush several times.check your book for type of detergent to use or ring & ask F&P.
May 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
I put detergant accidently in salt section dishwasher
if yo run the dishwasher a few times it should flush it through
Sep 27, 2009 | Dishwashers
Which detergent for Haier HNS1260 washing machine.
Yes you can use liquid detergent, If your's is a high effeciency machine, use HE detergent. It cleans as well, but makes less suds, which can cripple a front loader. Alternative HE detergents can be made at home,if you're interested. They can be either liquid or dry. You can find the recipes on YouTube, with the search set to "Homemade Laundry Detergent". We make the dry version, and it works better than anything we can buy. It costs us .02 cents per load.
Back to your question, though. If you intend to use liquid detergent, look into your dispenser and see if there is a moveable divider that you can change for liquid or dry detergent dispensing. Set it to the appropriate setting if it does. If not, use very little detergent, and you may have to add it directly to the load, skipping the dispenser altogether. Another thing that you might consider is that, if you ever have to have any warranty type work done, and the tech discovers that you have used liquid detergent, they will want to void your warranty.
Best regards, --W/D--
Aug 20, 2009 | Haier Washing Machines
Laundry Detergent
this usually depends on the type and brand of detergent you use. for example if you use standard detergent and it takes 1 cup, then you use concentrated detergent and it takes 1/2 cup. you have to check the detergent container for proper amount to use. for most detergents it is around 3/4 to 1 cup of detergent.
Ps. dont forget to rate my answer please. Thanks.
Dec 27, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing instructions
My book says for the Axxis WFL 2050/WFL 2060 : from the left while looking at it from the front: detergent for wash, stain remover, middle: fabric softener, fabric conditioner, right one: detergent for soaking agent. (Do not use chlorice bleach in this wasking machine).
Oct 11, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Water overfowing
can you remove the soap drawer and clean it .Ther may be a build up soap in the drawer assyor your water pressure may be to strong try turning down the taps.if you ring the manufacture thay may have an operating book.hope this helps.
Mar 13, 2008 | Creda W100FW Front Load Washer
LG LD-2160 dishwasher
Get an aqua vac and suck out the water (with the dissolved detergent)from the salt container. Refill it with water and repeat the process couple of times. Fill the container with water and salt and it should be fine. Good luck !!
Jun 28, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
Aqua Vac Tiger Shark Logo
Top Aqua Pool & Spa Experts
Ben Clacy
Ben Clacy
Level 1 Expert
ray gallant
Are you an Aqua Pool and Spa Expert? Answer questions, earn points and help others
