Question about Creda C362E Electric Kitchen Range
CAN I CONNECT A CREDA 2000W PLINTH HEATER USEING A FUSED PLUG?CREDA 2000W PLINTH FAN HEATER
    Scholar:
  • 68 Answers
Yes ,you can and fuse at 13amp.
Although the correct way would be to terminate the plinth heater in a switched fused spur or an unswitched fused spur fused at 13 amp
This can either replace a single or double socket or it can be taken of the socket by using 2.5mm2 twin and earth cable.
All parts availiable from hardware store or electrical retailer
Posted on Oct 06, 2009
Testimonial: "THANK YOU SO MUCH IT WAS VERY HELPFULL"
Oven fan sticking
Probably not. The only real cure is to replace the fan motor. Don't forget the nut folding the fan blades on often has a reverse thread.
Aug 02, 2014 | Indesit Ariston Creda Hotpoint Cooker Fan...
My heater won't turn off ... the thermostat is uh524ta or qmark581320500000. Can you help with a replacement thermostat? David
fan motor control switches are set for 130 degrees to start and stop the fan, yours is fused shut so the fan will not turn off, there will be 2 such units in your heater the other is the high limit gas cut off switch locate your fan switch usually has an egg shape with a screw or nut holding on each tab,,so 2 screws or nuts, mark the locations the wires connect to the switch, some have a 3 wire unit, bring the faulty switch to a local plumbing and heating outlet and simply match yours to any available unit in the temp range yours is set to or 130 degree limit, and also has the same wire count, should be around 15 bucks or so good luck
Feb 28, 2011 | Fahrenheat Ceiling-Mount Industrial Heater...
Creda Capri Oven - Ignition
I downloaded the manual from http://www.manualsmania.com and here is the section on replacing the battery:
Use an alkaline AA battery.The battery holder is located in the plinth panel below the oven door.Open the oven door fully. Press the tag on the left hand side of the battery holder/cover and withdraw it just enough to get access to thebattery. Fit the new battery with the end marked "+" on the same side ofthe battery holder as the red lead. Replace the battery holder by pushingit firmly into the hole in the plinth.
Jun 03, 2010 | Ovens
How to install a wall dimplex thermostat to a dimplex fan wall heater /RDH2010tcw/1000/2000W/240
disconnect wire A from the thermostat, and connect it directly to one of the supply wires. Connect B and C to the other for 2000W.
Mar 03, 2010 | Heating & Cooling
I have a 1999 Jeep Wrangler and the heater fan stopped working for all the fan speeds. The fuses are fine. How do you know if it is the blower resistor or the blower motor?
If you bypass the resistor pack and connect the motor directly to the fused 12v supply then the fan should run at maximum speed. If so, it's the resistor pack that's blown: a very common fault on a huge number of makes and models.
Feb 13, 2010 | 1999 Jeep Wrangler
1992caravan turn signals, low beams, and heater motor do notwork
A) Faulty turn signal switch or circuit.
B) Broken dimmer switch or poor electrical connection.Could be relay also.
C) Unplug the electrical connector at the motor and use fused jumper wires to connect the fan motor directly to the battery. If the fan still doesn't work replace the motor. If fan works could be your relay.
Jan 19, 2009 | 1992 Dodge Caravan
Not heating up
If fan is working o/k , then you need to replace the heater element.
This is located behind a removable panel at the rear of the oven compartment,
Undo screws and remove element .disconnect leads, be careful not to lose them inside, fit new element, fit cover back.
Plz rate this solution.
Tthanks, and merry exmas.
Nov 16, 2008 | Creda C362E Electric Kitchen Range
Creda grill
check the breakers at the breaker box. they probably kicked out. turn off, then back on. see what that does. (be sure the wires aren't touching any bare spots this time).
Aug 03, 2008 | Creda C361E Electric Kitchen Range
Creda C362E Electric Kitchen Range Logo
250 people viewed this question
Top Creda Kitchen Ranges Experts
richie46
ray gallant
Pamela Leach
Pamela Leach
Are you a Creda Kitchen Range Expert? Answer questions, earn points and help others
