Question about Kenmore Washing Machines
My frontloading kenmore model # 417-290-42992 wont drain
My frontloading kenmore model # 417-290-42992 washer wont drain? I read about unclogging the pump, but can't get the front panel screws to budge so I can remove face and check out the pump? any suggestions,Leesa
zeusfaber
  • 247 Answers
SOURCE: remove the front panel of a front loading washer frigidaire
This doesn't look like the best designed machine in the world for getting access to the drain pump.
You aren't going to get in through the front. Don't attempt to remove the door seals (only bad things will come of this!)
Looking at the diagrams in ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/5995464004.pdf, I think your best route in is to tip the machine back (careful it doesn't topple onto you) and go in through the bottom.
Your first target is the strainer shown as item 40 on page 6. If that's clear, then look in items 41 and 35.
Use the coins you fish out to buy yourself a celebratory drink.
A.
A.
Posted on Jun 29, 2008
  • 130 Answers
SOURCE: Door opens on the wrong side
Usually not. If you can you will need a door kit from sears. But in most cases the manufacture does not want to mess with the doors seal, so they dont offer a change.
Posted on Jan 24, 2009
  • 61 Answers
SOURCE: kenmore #417 frontload dosn't drain or spin, makes
if you need a part check out www.appliancepartssolutions.com
Posted on Nov 18, 2009
rickead1
  • 1998 Answers
SOURCE: How to place the spring
are u talking about the spring that holds the rubber gasket on the door? if this is the one your asking about heres how to instal the spring first you need a flat head screwdriver secondly properly seat the gasket allthe way around so that it sits down firmly into the groved slots when you go to install the spring start at the top and make sure that when you put the spring in the hole that is properly seated when you start to get down toward the bottom area you will have to use a flat head to pry the remaining section of the spring over the edge its best to do this as close to the spring section as possible make sure you go around every single spot to assure that you have seated the spring in the right way if you havent it can rip the gasket I hope this opinion helps in your appliace situtation and if i can answer anthing further please message me back have a great day
rickead1
Posted on Aug 22, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore frontload washer and the fabric
It appears your dispenser solenoid has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
How do i unclog it
I would need the full model number of the machine to give you exact directions. It's usually found inside the door. It's probably locked so i will instead point you to step by step videos. You will have to decide which apply to you. If you watch three or four of these videos you will be ready to tackle whatever you come across. Here's a tip though if your tub is full of water and if you have a shop vac. Remove the paper filter in the vac and vac-up the water as it flows from the hose when you loosen it. You can even control the speed of flow if you are careful. Don't get in too big of a hurry. Hope this helps:
http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump&oq=kenmore+elite+front+load+washer+drain+pump&gs_l=youtube.3...6810.10693.0.11258.10.10.0.0.0.0.309.2085.2j0j6j2.10.0...0.0...1ac.1.Xyo8NnP2UHU
Jan 21, 2013 | Kenmore Elite 45986 Front Load Washer
I purchased a Kenmore frontloader washer & dryer yesterday from Sears...it was a floor model. The owner's manual was missing and I was told I could get one online...help where and how?
I wrote a tip about these washers. I include a service manual. It is best you read this before attempting washes. It will save you a lot of grief. DUET SPORT
Oct 23, 2010 | Kenmore HE2 Plus Front Load Washer
My washer sounds like it's dying, but the dryer is fine. Can this be unstacked so all I have to do is buy a new washer?
Welcome to FixYa.
To answer your question, as long as it is indeed a frontload washer with the dryer on top, yes they can be replaced individually.
The model number provided is only partial, therefore I can`t verify the unit is frontload or an Kenmore integrated "laundry center" built by frigidaire.
You can reply with a model number, but as I alluded to if it is frontload, no problem.
Good luck going forward. Thank`s for choosing FixYa. Let me know if you require further assistance.
Macmarkus :)
Aug 25, 2010 | Kenmore 43142 Front Load Washer
My kenmore elite frontloader washer will stop 2-4 times during a regular wash with a flashing F02. I have to push cancel and then start again and it resumes the wash. I also have the suds light come on...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((((
May 20, 2010 | Kenmore Elite 45986 Front Load Washer
KENMORE FRONTLOAD WASHER Model# 41741052000
very common for the tub seal to leak - or bellow to be ripped.
Aug 07, 2009 | Kenmore 44102 Front Load Washer
Kenmore Elite F02 code even after changing to a new pump.
remove compartment cover under the front load door. There is a drain there that will catch large items left in your clothes, ie pens paper etc
Apr 01, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Please help , tell me why door is locked, on h 2 kenmore washer,
THANK YOU,
still nothing,
red doorlock light on, wont do anything,
I have to unplug so it will shut off,
when I plug in and hit start, red light stays on again,
Mar 28, 2008 | Kenmore 4292x Front Load Washer
Washing Machines Logo
70 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
