Question about Dell Inspiron B130 Notebook
Hi! I try to boot up the dell, but get the error message that "The device in the system modular bay cannot be identified." and when i get past that, i get "no bootable devices". What do i do?
    Problem Solver:
  • 9 Answers
Sounds like your harddrive is not being read depending what operating system for windows its usually f8 to try and start in safe mode. if that does not work after you turn it on if you see a message at the lower left of your screen telling you to hit f2 or f10 try that. One should get you to a configuration screen take a look and see what your boot order is. Your HDD should be first but it can be disabled stange things happen if your computer getts unpluged vs properly shut down. I had a laptop once that suddenly could not access my modem after i tried to condition the battery turns out the factory default was for the infared port to link to an external modem keeping it from communicating with my modem.
Posted on Oct 06, 2009
  • 48 Answers
  1. check bios setup and set proper setting for sata hdd device.
  2. remove hard disk and refix it
Hi my dell d610 does not recognise any dvd rom i
insert a good quality dvd in the drive. If no response, go to my computer and select dvd drive and double click, it may open. GL
Aug 19, 2013 | Dell Latitude D610 Notebook
Dell Inspiron 1100 problem
For Dell Inspiron 1100 Support just dial 1-800-204-4427 Dell Inspiron laptop support number to fix you error by expert technician. For more Click here : http://www.delltechnicalsupportphonenumbers.com/dell-inspiron-laptop-support
Jul 08, 2017 | Dell Inspiron 1100 System Board (...
Hello Need help I get error below and don't
one of the devices connected to your MB isn't connected properly.
try to remove them and then to install it again
Nov 14, 2009 | Dell Inspiron 2200 Notebook
Either issue with system modular bay or system file removed
remove any cd or floppy disks from the pc...reboot ..if the black screen reaper with the same message about the missing file ..you have to insert the windows instalation cd ...and repair..the missing file
Jan 28, 2009 | Dell Inspiron 2200 Notebook
I need solution
Ok, this is a misworded error message on dells end. this laptop does not have a modular bay instead it has a locked in disc drive. Based on what i have seen on other dell laptops i would have to say the cd drive is going bad. To test this try removing the cd drive. Power the laptop on and push the eject button then power the laptop off. Flip the laptop overand there will be a screw to hold the drive in, this screw will be close to the center and will be the only screw in a square hole, remove this screw. Now if you followed my directions, you should have the drive out. Pull the tray out as far as it will go then grab the two sides closest to the laptop and gently pull it out. If you are having problems you can stick a flat screw driver in the square hole and push the piece of metel to the side to remove.
Now power the laptop on it may say something about there not being a cd drive(optical drive) if it does not say: "the device in the system modular bay cannot be identified" then you need to replace to CD drive.
Dec 04, 2008 | Dell Inspiron 2200 Notebook
It won't boot to the os
The modular bay refers to the optical drive (CD drive). There is a small screw holding it, I've had machines at my shop that this screw fallen out and the drive wasn't making a good connection. Be sure that the drive hasn't slid out a bit. Take it out clean the connection and put it back, making sure it's seated properly. Try this, then let me know, and we'll go from there.
Jul 29, 2008 | Dell Latitude D600 Notebook
This screen comes up when it is turned on: "The device in the system modular bay cannot be identified, etc.
I had the same problem.  I took out the optical drive, and powered it on, and it worked.  I may have to purchase a new optical drive?
May 22, 2008 | Dell Inspiron B120 Notebook
Bought second hand c640
Power off even it it takes a battery removal. Now check modular bays and remove then fully insert each device and retry power up. If same results, try repeating above with one of the modular devices removed.
Sep 09, 2007 | Dell Latitude C640 Notebook
Dell Inspiron B130 Notebook Logo
628 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
