Question about Zenith IQB50M90W 50" Rear Projection Television
Picture jumps on screen
My Screen just started to go in and out t
LINES ACROSS TV AND PICTURE JUMPS UP AND DOWN HOW TO FIX
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 05, 2014 | Televison & Video
Element flat screen 32 inch screen jumping and has green lines
I think if it was me I would return for exchange, refund or repair.
Dec 09, 2012 | Televison & Video
Picture looks like it is jumping
Sounds like a vertical sync issue on the chassis board. However you also mentioned the picture moves left to right or vice versa which would suggest a horizontal sync issue. Either issue is not repairable by the DIY. Sync issues must be isolated using test equipment usually found in repair shops. My suggestion push it down a hill and enjoy the show then go buy that flat screen you almost purchased last week.
Jul 25, 2009 | Toshiba 42H81 42" Rear Projection...
HP Pavillion dv800 screen jumps but has clear picture
mon loptop s'allume mais l'écran ne montre aucune images.merci de m'aider
Apr 06, 2009 | HP Pavilion dv8000t Notebook
Jumping picture on Toshiba flat screen model 36HF732
see ur proplem is u hit up or down or previous to much and it thinks ur still pressing it if u have a bos just turn it around and hit reset beleive me its happened before
Mar 26, 2009 | Televison & Video
Picture jumps
you might have bad caps or the vertical output integrated circuit, try to locate the vertical ic and check the surrounding areas for bad capacitors.
good luck
caypianan@yahoo.com
Oct 23, 2008 | Hitachi 53SWX10B 53" Rear Projection...
The camara won't show a picture on the lcd screen
Your lens is Damage. Prevent nextime from sunlight , it damage your lens if not in use.
Dec 24, 2007 | Canon PowerShot A75 Digital Camera
Mitusuhuibi big screen
start shopping around for new TV
good deal jan 1
Dec 14, 2007 | Mitsubishi WS-55807 TV
Screen flicker/jumping
first check loseconection and tube light and nearaset spk for sparking .and check the earth of monitor main waire
Nov 18, 2007 | ViewSonic GA771 Monitor
Jumpy / Schrolling Picture...?
this is a problem of synchronization.  are there any adjusting knobs in the tv set (vertical hold adjust) if  yes you can try but if none maybe consult a technician.
Oct 30, 2007 | Akai PT5492S 54" Rear Projection...
Zenith IQB50M90W 50" Rear Projection Television Logo
21 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
