Question about Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop
When i turn the pc on it goes to hit f1 to cont of f2 and then it says it can not read the hard drive
    President:
  • 1,653 Answers
Before doing anything else power off the machine, remove the cover and then make sure that the power and data cables are seated correctly in the Hard Disk. Reboot the machine and see if this works. If not then turn off the power and swap the hard disk power supply for one of the spare plugs in the unit and try again. If this fails then Restart the machine and hit F12 or DEL to go to the BIOS. Take a look at the standard settings to see if the system can see your hard disk or not. If it can this is better than if it cannot. If you have a system restore CD then change the startup order in the BIOS so that the first device that the system looks for is the CD/DVD. Place the restore disk in the CD/DVD drive then save and exit the BIOS settings. The system will then reboot from the CD/DVD and read the restore disk. Then follow the instructions on screen to hopefully restore your system. If the Hard Disk is not recognised then you have more of a problem but try the same restore process as above. If you do not have a restore disk but have an operating system CD then place this disk in the CD/DVD drive and go through the process above. Once this starts up choose the Repair Option and follow the instructions on screen. You may be successful in restoring / rebuilding your machine but you may have to face the fact that some of your data may be lost. If it fails then at worst you will have to buy a new hard drive.
Posted on Oct 06, 2009
  • 4,281 Answers
First open cpu cabinet.
Then reattach both connection cable power cable and sata or ide cable to harddrive.
Then when you power up the computer press F1 or F2 or "del" key to enter in bios then check there your harddisk is detected?
If your harddisk is detected in bios you can boot your harddrive.
Let me know if you need more assistance.
Thanks.
Ever time I start my computer I have to Ihit F1
go into bios and change your boot up start from CD/DVD to hard drive then you wont get f1-f2 error.
Jan 21, 2014 | Dell XPS Computers & Internet
Heloo sir i have a problem with my dell 170l when i start it it shows ''strike F1 to continue, F2 to run the setup utility'' when i click f1 it show ''f1 to retry boot,f2 for setup utility'' plz help me...
Hit F2,look in setup to see if the hard drive is recognized and check that the date and time are correct.
Then hit esc key. it will ask if you want to save changes, click yes. It should boot and probably ask you to hit F1 or F2 again., unless there is a problem with the CMOS battery, which may need to be replaced.
If you hit F1 to continue, it will boot, but your time and date will be off.
Dec 17, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
My dell 5125 indicates internal hard disk drive not found. it asked me to reseat the drive...than it indicates no bootable devices- i'm strike F1 to retry to boot and F2 for setup utility....nothing...
Try accessing setup utility and verify there if it still recognizes your hard drive, if not then that means your hard drive had crashed. If you have important files on the drive, you can try to recover it by going to a local service provider and have your files recovered, and of course you have to get a new hard drive for your dell.
Sep 13, 2010 | Computers & Internet
ACER ASPIRE 3680 --OPERATING SYSTEM NOT FOUND
its showing operating system not found, because the system cannot detect your hard disk.
Open your system, remove and fix back the hard disk, then try again.
Take care.
Mar 03, 2010 | Computers & Internet
Primary disk drive not found
Check the connection of your hard drive and make sure it's plugged properly On The Motherboard.
Is this a SATA drive? Has it ever operated properly? If worse comes to worse, you'll have to reload windows from scratch.
Nov 11, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension E521 ''Diskette Drive 0 seek failure''
Is there a diskette drive installed?The bios is looking for a device that was enable but not there.If you prefer to ignore this problem you may do so,however the fix is very simple,unplug the computer remove the cover,there is a coin battery which stores the configuration of the computer you may need to remove it.This will erase the configuration stored in the bios,or you can install a jumper on the motherboard which will clear the bios setting .Remember to return the jumper on the pins it was on.
good luck
Jul 01, 2009 | Dell Computers & Internet
Dell dimensions 3100
sounds like your floppy drive is failing, you could get it replaced or simply turn it off via the BIOS.
to turn it off simply hit the F2 key. On the first screen usually it will list your Hard Drives, CD ROMs', and the Floppy. scroll down to the floppy and hit enter ot the corresponding key form the bios's legend at the bottom or right hand side of the screen untill you see disable.
Next you can navigate to Save & exit or hit F10 to do the same. G/L.
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
No boot device available
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Apr 27, 2008 | Dell Latitude C640 Notebook
Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
