Question about HP Photosmart C6180 All-In-One InkJet Printer
Print catridge alignment failed
I get a print catridge alignment failed for my HPC6180
    Scholar:
  • 174 Answers
Hello there... I am not savvy about this topic but see this one. I hope this helps... If not, please let me know...thanks!
Best wishes, Ai-ai
Posted on Oct 06, 2009
    Scholar:
  • 92 Answers
Do a re-install.
Take it out using your manual as a reference and re-install using the same.
Should you not have a manual to assist you in the process, be sure to check on this site for a downloadable manual for your printer or go to the HP website to download one from there.
Wishing you success...
HOw do I bypass cartridge alignment?
its horrible the printer companies make you have to do it a nice easy way for them to screw you over the best is when it says my cartridges are empty but i can touch the bottom and get an ink covered finger i even bought the refill kit and found out i need the chip programmer too....check out the kodak hero series i have esp 3.2 hero it cost 60.00 works amazing and came with ink catridges and to top it off the replacement cartridges are cheap and print a ton of high quality images.
Sep 13, 2014 | Office Equipment & Supplies
I recently replaced my printer cartridges in my hp psc 2210 all-in-one and it printed fine the first day. Now all it will do is print the alignment sheets and won't let me copy anything. The...
alighment not sucessfully completed because of one of the catridge nozzles are clogged or carriage assm not reading the align page properly,check the align page is properly printed? if no repalce catridge, if print quality is good clean align reader which was located beside of the carriage... best of luck
Sep 07, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Hp laser jet cp3505 printing only black and white pages.not printing colour
Its mechanical mis alignment problem,remove main motor assm which is located right side,you will find out four gear wheels row enguaged with other gears.. Upper 1st gear drives the mono catridge, remain three ment for colour catridge drive. Open this mechanism & absorve that each gear having align markings marking.If this alignment got distrubed you will get quality issue. Its very easy to understand to match each gear, take help of service manual suits clj 3600,3800. Try it...if fails try it up to sucess.... Best of luck..Vinay.
Sep 05, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
I keep getting the message Alignment Failed.
hello deer1626, if a printer gives you a message alignment failed that means your catridges are not properly installed try removing the catridges and fixing them back you will get a notification of aligning just follow the onscreen instructions and thats all
Jan 03, 2011 | HP Officejet Pro L7680 All-In-One Printer
CATRIDGE ALIGNMENT COULD NOT BE DONE
Remove the catridges and the print heads insert them properly again and repeat the alignment process.
May 26, 2010 | HP Officejet 5610 All-In-One InkJet...
Cartridges alignment problem
To align catridges:-
  1. Load plain paper.
  2. Press the Menu button, and scroll to Align Cartridges.
  3. Press Select. An alignment page prints. Once this page prints, your automatic alignment is complete
To do it from your computer:-
  2. Open the lexmark Series Utility.
  3. From the catridges tab, click align catridges.
  4. Click OK to print alignment page.
  5. This will be make the alignment successful. If not successful, it should be done manually.
Aug 25, 2009 | Lexmark X4270 All-In-One InkJet Printer
Tops and bottoms of letters are cut off. I have changed the ink cartridge
Replace the old ink cartridge.
Verify that the unit is on. The On button is lit when the unit is on. If the device is not on, press the button to turn on the unit. Open the print cartridge door. The print carriage moves to the far right side of the unit. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. When replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. When replacing the black or photo print cartridge, remove the print cartridge from the slot on the right. Pull the print cartridge toward you and out of its slot. If the print cartridge is being removed because it is low or out of ink, recycle the print cartridge. Remove the new print cartridge from its packaging. Remove the plastic tape by using the pink pull tab. Removing the Tape from the catridge.
  1. Will have Copper-colored contacts.
  2. Plastic tape with pink pull tab ( must be removed before installing ).
  3. Ink nozzles under tape
  4. The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  5. Top & Bottom not printing properly.
  6. Load unused, plain, white letter, A4, or legal paper into the input tray
  7. If coloured paper is loaded in the Input tray when the print catridges are aligned, the alignment will fail. Load unused, plain white paper into the input tray when the Printer catridges are aligned, the alignment will fail. Load and unused plain white paper into the Input Tray and then try the alignment again.
    1. Press 6 to select Tools .
    2. Press 2 to select Align Print Cartridge The unit prints a print cartridge alignment sheet.
    3. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK. Now the printer will print properly.
Jul 29, 2009 | HP Officejet 4315 All-in-One Printer
Quality of colour
hi! there, well in connection to your poor printed color there posibility that ink was insufficient to distribute to you photo to print try to visit your ink status, black color is sepated to 3 color catridge.if there's a insufficient ink in catridge,replace or refill any thing as long there is much ink in your catridge,if ok and print still not good,try to clean your printer headdont use any thing to clean your printer herad,the printer will clean your printer head,on maitenance menu,click clean,try several time,also try to align your printer head,click aligned,t check the pattern of your printer,click pattern test.if ok try toprint if the color print is balance,try to print.check the preview before you print adjust the quality color as in yout tate before printing.regards and have a nice day.
Apr 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Do not see align or clean catridges at preferences /features
hi,
To Align the cartridges, please perform the following instructions.
  1. Load unused plain white letter or A4 paper into the input tray.
  2. Press the Setup button.
  3. Press the down arrow button to select Tools and then press OK .
  4. Press the down arrow to select Align Print Cartridges and then press OK . An alignment page prints.
  5. After the success or failure message displays, click OK to continue. Recycle or discard the alignment page
Regards,
Sagarjd
Nov 21, 2008 | HP Photosmart C4180 All-In-One InkJet...
Won't print anything. always wanting to print a test page
hi this is a ink catridge align ment problem. u do one thing. go to printer properties and printer priference and go to service tab than u check ink catridge align ment.. than ur printer working fine...
Aug 18, 2008 | Lexmark X2500 All-In-One Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
206 people viewed this question
Seeker5211
Seeker5211
