Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Locked door on my GE Profile Oven (Range)
I went to use the self cleaning mode on my oven and stupidly opened the door seconds after starting it and now the locked door is on and wont do anything else. I have unpluged the oven and reset the circuit breakers and still it says "LOCKED DOOR". I have cleared and even tried to go through the cleaning cycle and it will not do anything. Please please please HELP!!!!! My husband is going to flip!
Amazing. I've searched across the web, and this "locked door" problem appears to be a DESIGN FLAW across the entire product line: if you run the self-cleaning cycle, it WILL trigger this problem and despite the suggestion of a wide range of "self-help" strategies, the only real solution is to pay for a service call (and then, it appears, paying for a new control unit and probably an additional service call to have it installed, and then more service calls if the same problem occurs). We have a JGB900BEF2BB GE Profile range, and of course we've run through all the self-help suggestions at geappliances.com and on a dozen other web sites like this one.
Posted on Aug 17, 2012
fridgetech
  • 473 Answers
SOURCE: model JBP79 FFFcode
FFF Control Error, Failed EEPROM Replace Control
Unfortunately when you get this code the oven control will need to be replaced.
Posted on Nov 12, 2007
jessee007
  • 310 Answers
SOURCE: After self cleaning, Range trips circuit breaker when using convection
self cleaning ovens use super hot seting to bake the oven clean and it sounds like it melted a wire and it is shorting out the oven on that setting. look at the wires you can see or easy to remove panels
Posted on Jan 01, 2008
SOURCE: GE Profile Still Heating with nothing selected
OK, I have the same problem with my oven heating even though it's turned off. This started after normal use, not the self-clean. My model is a GE JKP56BD1BB double oven built-in range. Only the bottom oven heats, the bottom oven is off.
I have replaced the oven control (and yes it is expensive) and the top oven continues to heat continuously.
What's next? These parts are expensive.
Posted on Feb 27, 2009
protek480
  • 1714 Answers
SOURCE: ge electric range ahas no power, circuit breaker
Unplug the range and try to reset breaker. If it holds, you have a shorted element or some kind of fault in the range. If it won't hold in, change breaker
Posted on Aug 04, 2009
  • 42 Answers
SOURCE: I have a GE jbp24 free standing electric stove. I
sounds like something has burnt out on your clock/programmer.
Posted on Sep 30, 2009
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
Can't unlock oven door
Put the oven in self clean mode, it will lock the oven, once the self clean mode has started turn the self clean mode off, give it a second and the oven should turn off. Same thing just happened to me and it worked.
Dec 24, 2010 | KitchenAid Ovens
Door to oven locked wont open
u can try unplugging the range for five min , if that dont work , get its electrical checked out
Apr 21, 2010 | Kitchen Ranges
Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Jan 13, 2009 | Kitchen Ranges
Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
Feb 16, 2008 | Kitchen Ranges
Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Feb 10, 2008 | Kitchen Ranges
Oven door open
Turn the operating mode dial to self-clean, then manually hold in for about 20 seconds the light pin on the oven rim. The lock will eventually open after 20 or so seconds. Turn off the operating dial and the door will close.
Jan 12, 2008 | Ovens
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
201 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
