Question about Sony Cyber-Shot DSC-P73 Digital Camera
When the camara turns on the word 'access' appears then the camara shuts down. New batteries have been put in but still no joy.
My camara wont turn on
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Aug 27, 2009 | Kodak EasyShare M863 Digital Camera
Camara Kodak M1063 not charging
BATTERY MAY BE SHOT. FIRST MAKE SURE
ALL CONNECTIONS ARE TIGHT AND CLEAN.
IF THIS DOES NOT WORK, U WILL NEED A NEW BATTERY
Jun 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
New Samsung sch-430 won't shut off
try taking out the battery for five minutes
Mar 30, 2009 | Samsung SCH-u430 Cell Phone
Camara can't be turned on normally
I have to take out batteries and put them back a few time to turn on my camara in display or viewfinder mode. At first i doubt my battery's problem and replaced with new batteries, it was the same
Jul 18, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
Vivicam 8400
I have a ViviCam 8400 and have the same problem UNLESS I buy Duracell Power Pix or Energizer Titanium batteries. These cost more than the regular grade AA batteries, but when I used brand new regular batteries, the camera would turn on for 2 seconds then turn right off. Titanium or Power Pix batteries make the camera work fine. And, because they are made for digital media, they do allow you to use the camera for longer periods of time.
Jun 09, 2008 | Vivitar ViviCam 8400 Digital Camera
Lens Error
HI MY CAMARA IS TURNING ON EJECTING LENS THEN IT GOES BACK IN RE SPITS LENS OUT THEN COMES UP WITH THE LENSE ERROR I HAVE PUT NEW BATTERIES IN REMOVED THE CARD BUT STILL NO JOY WHAT DO I NEED TO DO.
THANKYOU
JULIE
Feb 22, 2008 | HP Photosmart M525 Digital Camera
Shutter problem with a sony dsc-w30 camara
Make sure the battery is strong and not failing you and that the extending lens cover parts are clean. You may have gotten something in there.
Dec 24, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Help need to fix camara for work
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. you need professional service to fix it.
Sep 07, 2007 | HP Photosmart M22 Digital Camera
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
CAMARA SOFTWARE PROBLEM
Does your battery work with regular AA alkaline batteries ? They have higher voltage than NiMH rechargeable. I'm having a similar problem, just discovered today that my camera works fine with AA alkaline batteries.
Sep 19, 2006 | Samsung Digimax A7 Digital Camera
Sony Cyber-Shot DSC-P73 Digital Camera Logo
37 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
