Question about Sony KP-51WS500 51" Rear Projection Television
Fading blue screen
I have a 51 inch projection from 2003 after it is on for a while the picture fades out and all you are left with is sound and the screen is all blue. You can see faint images but not much. I f you turn the tv off and then back on the picture is back but only for a while. 51ws5000
    Top Expert:
  • Sony Master
  • 14,553 Answers
You may have a bad blue picture tube but there is a way to deal with this first---This is a 2003 model ---I did one of these with the same problem a week ago---the set has a black plastic block with six controls---three are Focus(red,green,blue) the other 3 controls are Screen controls(red, green, blue) Someone has to remove the entire piece on the front of the set below the screen(usually a plastic part) most of the time it is secured with 3 screws on either side of the set in the back; once you remove the screws the entire piece should pull out(pull from right to left(it will not fall off or come out easy--it is held in with several large plastic pegs) With it removed there is an inspection plate with 4 screws-----the screen/focus block is behind it.
You need to look very closely at the block to identify the focus versus screen controls----one row left to right will be marked Focus and the other row left to right will be marked screen------YOU need to locate the Blue Screen control(they are black like the block) With the set on(be careful) go to a video input with nothing connected---if you see a blue screen as well as the input number turn the BLUE SCREEN CONTROL SLOWLY TO THE LEFT UNTIL THE BLUE is gone.
If this cures the problem you may only be buying yourself some time----if the blue picture tube is bad sooner or later this trouble may return----I have seen sets where this was adjusted and the set worked for a year or more with no repeat of the trouble----replacing the blue tube would likely cost you 400 - 500 parts and labor.
IF YOU HAVE ANY QUESTIONS OR NEED ADVICE LET ME KNOW- I am here to help people.
SD TECH
Posted on Oct 06, 2009
Testimonial: "I tryed it and it was all ready all the way to the left.. Nice try anyway.. Thanks..."
Screen on my HL-R5667W DLP is fading from the left
Ur tv have a convergence problems.The 2 STK convergence ICS are defective and dying.The shop will fix this for u about $300-350 for parts and labors.
May 08, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Blue screen after awhile
This is one of a group that had bad picture tubes(red,green,blue). They are no longer available unless they are removed and rebuilt and that is very expensive.
There is one other thing you may be able to do to get the set to function again without replacing the blue picture tube---Reply here to me if you want this information and I will post it here.
SD TECH
Sep 20, 2009 | Sony KP-51WS500 51" Rear Projection...
Blue screen no picure good sound
Check your video inputs or cables for wear from the signal your using. Does it do it on other inputs (DVD, game etc??)
Sep 05, 2009 | Sony KP-51WS500 51" Rear Projection...
Images fading fast. Cannot read text on screen. Could hardly focus on images. Need to obtain part: Screen Focus Block
The lens is getting clogged. All u need if u have little expertise open up the TV.
and clear the lens or projection hd there with a soft clean cotton cloth
May 29, 2009 | Hitachi 51F59 51" HDTV Projection...
48'' Rear projection picture fading
sounds like your color wheel is fading.
Mar 31, 2009 | JVC Televison & Video
Normal pictures fades to blue screen within 30 seconds
The fix for this is here somewhere, as I had the same problem last January and the solution was posted here in March last year. I'll try to find it and post the link to it for you, later.
Nov 06, 2008 | Sony KP-51HW40 51" Rear Projection...
Blue screen
This is easy to fix, pull off the front grill and turn the bottom left trim pot anti clockwise until the picture comes back. I am asuming the picture there and then it fades to blue. There is a step by step instruction on how to get the whole thing apart http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 15, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-51HW40 Sony 51" Fades to blue screen
The service manual on page 8 shows how to adjust the Red/Blue/Green screen voltages. To get to the adjustment board, take the front speaker grill off (two screws at the bottom left and right) and set it aside. No need to disconnect any wires. Then remove the plywood board with 4 screws that exposes the screen/focus adjustments. The top 3 adjustments are for focus, and you need not mess with these. The bottom 3 adjustments are for Red/Blue/Green screen voltage rough adjustments. My screen showed red lines, so I had to turn the bottom right adjustment with a philips head screwdriver just slightly until the red gun retrace lines where no longer visible.
Aug 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Kines on Screen and Fading
Open up the front of the set by removing the speaker screen and the black piece of particle board. on the bottom right you will see 4 knobs. Turn those knobs slowly till the arcs go away. The 3 knobs on the bottom are for color. the 3 on top are for the focus.
Jun 30, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
167 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
