Question about Sony CRX225E (CRX225E1/10X) CD-RW Burner
Can't run a dvd on my computer, can you help me
Can run a dvd on my computer, can you help me solve the problem CRX225E CD-RW Burner
    Scholar:
  • 174 Answers
Hello there... In order for your DVD to play on your PC, you need at least the DVD-ROM or you install a DVD writer. You also can buy the external one - it's better. Hope this helps... :D
Best wishes, Ai-ai
Posted on Oct 06, 2009
SONY CRX225E NOT WRITING CD
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Sep 24, 2011 | Sony CRX225E (CRX225E1/10X) CD-RW Burner
Hi sony cdrw crx225e won't run when cd put in and won't burn music etc to disc. Device manager says product is working properly.
is laser burned, probably you dont respect the 10min burn wait (for laser colling), now you must buy a new cdr drive.
Aug 07, 2010 | Sony CRX225E (CRX225E1/10X) CD-RW Burner
CD-RW Door won't open with disc inside
You need to push harder in the pinhole, and do it while the power is off. That pinhole goes directly to a gear. If the gear is stuck and will not turn at all the drive will have to be disassembled to recover the cd.
Jan 06, 2009 | Sony CRX225E (CRX225E1/10X) CD-RW Burner
Disc tray doesn't open
Unplug and plug in the powercable then try again. Be sure that the cable goes in the powerslot as far as it needs.
Good luck to you
Dec 12, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
Hi CD rom cannot be detected
Thanks for your response. My problem is solved. I got some advice to go into the registry and delete the entry LowerFilters. My DVD drive works perfect now. Below is the info that solved my problem. This may help someone who runs into the same problem. Thanks again.
Go to Start>Run type: regedit click Ok. When regedit opens
navigate to
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane you will see a value Upper Filters and Lower Filters.
Rt click on each one and choose delete.
That should do it.
Jun 12, 2008 | Toshiba SD R2102 CD-RW/DVD-ROM Burner
ATAPI DVD+RW Burning Problem
DVD / CD-RW is usually a a combo drive
DVD PLAYER with CD BURNER
DVD-RW is a dvd rewritable drive
Dec 30, 2007 | KHypermedia (KHCRW522452) (20326452) CD-RW...
Sony CRX225E (CRX225E1/10X) CD-RW Burner Logo
107 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
