Question about HP Laserjet M2727nf Multifunction Printer
Feeder wont grab sheets
Wont grab sheets
  • 75 Answers
Open the cover of the document feeder you there will find two rollers (blue and grey) clean these rollers with a cloth dampened with nail polish remover
Posted on May 10, 2010
Paper feeder grabs several pieces of paper at once
The spot in which the paper is fed into could have a fence/blocker. Use wood or a little hunk of aluminum to only allow 1 sheet. You could get fandy and use a rod that could also be mounted on the font.Be crea8tive and good luck.
Jul 21, 2012 | Canon PIXMA MP530 All-In-One InkJet...
Paper wont feed
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Jan 09, 2012 | Lexmark X Office Equipment & Supplies
Lexmark printer wont print
Jan 04, 2012 | Lexmark X4650 All-In-One InkJet Printer
Printer wont feed paper
Try to reset your printer. Unplug the power adapter from the printer. printmastert_40.jpg
Wait at least 10 sec before replugging the adapter to the printer. Try to print again. If that doesn't help, there could be something in the feeder that's blocking the paper path. Remove the sheets of paper from the feeder and grab a flashlight and look inside.
Apr 27, 2011 | Lexmark X2550 All-In-One Printer
Paper will not feed into the printer, not even if I help it.
Suggestion, but not the answer.... Mine has same problem. I have to feed 1 sheet at a time. If the sheet is too high or too low, it won't work. Put 1 sheet in feeder, then gently push it down until it's 3/4" below the top of the feeder tray. Any higher and it won't grab, any lower and get jam message. What a pain! Finally bought wife a new printer and use this one for 'playing' and faxes. Bob
Sep 24, 2010 | Lexmark X5470 All-In-One InkJet Printer
I have an hp OfficeJet G85. The automatic document feeder won't work about half the time. Is there a way to clean or fix the feeder? Everything else works fine.
Depends on how the ADF is malfunctioning. If it just plain doesn't work, then you are likely looking at a control cable / connector issue.
If it grabs multiple pages at same time, or doesn't want to grab pages at all, you can try using a "cleaning sheet" available for inkjet printers. Most office supply stores will sell these. The cleaning sheet helps to clean the paper path (wheels, idlers, etc). You should also be able to pop open the ADF cover, and remove any paper debris that is present. See owners manual for this procedure though, it is easy to break the cover.
Aug 25, 2010 | Office Equipment & Supplies
My praftically brand new Canon Pixma MP620 printer grabs more than one sheet of photo paper and stops printing picture on first sheet then garbles several pictures on a portion of the next sheet. I just...
check the printer's printing preferences on properties option.should be set to normal then check the printer rollers if its dirty where the papers pass thru, if the problem persists load only 1 paper every time you print for the printer not to grab more papers.i think it is in the feeder and the sensor maybe its dirty need to be cleaned up.
Feb 22, 2010 | Office Equipment & Supplies
Vertical paper feeder for the copier not grabbing next original sheet
I'm having a similiar problem. Can't consistantly feed one sheet at time. If i load several sheets it pulls all through, etc
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Dell 1600n Will only print with sheet feeder open
Rollers may be worn out and not properly grabbing paper or a gear may be broken. You should be able to inspect by lifting cover to feeder and watching as paper is pulled through.
Dec 04, 2007 | Dell 1600n All-In-One Laser Printer
HP Laserjet M2727nf Multifunction Printer Logo
170 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
