Question about HP Officejet 5610 All-In-One InkJet Printer
I am having a problem wiht HP printer I replaced new cartiridge and it is stuck on adjusting cartridge
Joed911
  • 4338 Answers
SOURCE: HP C3150 Cartridge stuck
  1. Press the Power button (c01575386.gif ) to turn the product on, if it is not already on.
  2. Open the cartridge door. The carriage might try to move into the access area at the right. Allow it to move to that position.
  3. Wait until the carriage is idle and silent.
  4. Without turning off the product, disconnect the power cord from the back of the product. WARNING: You will move parts by hand in the following steps. You must disconnect the power cord to eliminate the risk of an electrical shock and to reset the paper-feed mechanism.
  5. Looking in through either the cartridge door or the output tray, make sure the cartridges have not come loose in the carriage. Push each cartridge inward to securely lock them in place.
  6. Check for and remove any obstructions under or around the carriage that might prevent it from moving.
  7. Make sure the carriage can move freely across the width of the product by firmly pushing the carriage to the left, and then to the right.
  8. Close the cartridge door.
  9. Reconnect the power cord to the back of the product.
  10. Press the Power button (c01575386.gif ) to turn on the product.
  11. Allow the product to warm up, and then try the print job again.
  12. Check the cartridges for damage: NOTE: The product must be on or it will not release the cartridges.
  13. Wait until the carriage is idle and silent, and then lightly press down on a cartridge to release it. Pull the cartridge toward you out of its slot.
    • The tri-color cartridge is on the left.
    • The black cartridge is on the right.
  14. Check the cartridges for damage, and then replace any damaged cartridges. Check for obstructions under and around the carriage. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
  15. Follow these instructions to install the cartridges correctly.
    1. If you are installing a new cartridge, remove the cartridge from the packaging, and then remove the pink-protective tape.
    2. Hold the cartridge by its sides, with the contacts facing into the carriage.
    3. Slide the cartridge at a slight upward angle into the empty slot, and then gently push it until it snaps into place.
      • To install a tri-color cartridge, insert it into the left slot.
      • To install a black cartridge, insert it into the right slot. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
        Thanks, Joe
Posted on Nov 11, 2008
Joed911
  • 4338 Answers
SOURCE: Won't accept non-HP cartridge
You ask "Is this a common problem with non-HP cartridges? " It is a possiblity.
Where did you purchase the cartridges from?
This error might be caused by defective printhead or sensors
Are you removing the 2 protective caps from the cartridges?
Read this HP page:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01451117&lc=en&dlc=en&cc=us&lang=en&rule=17507&product=3203059
Click on this link or copy and paste the complete link into your browser.
Thanks, Joe
Posted on Apr 23, 2009
Semi-Driver
  • 434 Answers
SOURCE: I have a HP C4100 printer and I'm having trouble
I hope this tutorial (with video) is helpful:
HP C4180 Replace Cartridges
Posted on Jan 01, 2010
SOURCE: Hp M1005 Laser printer showing no print cartridge ...
hi
it means you have a paper jam
open up the tray, take the paper out and place back.
switch off printer and turn back on.
i have just found this on the internet myself and I have struggled for a week, but now ok...
Posted on Jul 30, 2010
  • 360 Answers
SOURCE: I have an samsung printer
hello ,
replace new toner chip
Posted on Aug 31, 2010
I have HP 2575 PHoto smart. I just installed the driver from the HP official site. However, everytime I tried to print, the printer is stuck at alingning the printer cartiridges. I ahve check the...
You do not have to align the cartridge by taking out and replacing it. All you have to do is to Go to control panel, right click on printer and then go to Properties. Select Properties and the click on Maintenance tab and then click on the cartridge alignment. The computer will automatically will do the alignment and print a test page. If it does not confirm to your requirement do it again till you get the right printing
Aug 28, 2010 | HP Office Equipment & Supplies
Hi, I have a Lexmark X7170 Multi-function printer/copier/scanner and it is showing an error message "left cartridge incorrect". I have not charged the cartridges and I have tried to re-align it. Any ideas?
it means your left cartiridge got some problem, might be it got short and you have to replace that.
try this remove your left cartiridge and then try to print if it work then its clear that your aother cartiridge is gone and you need to change it.
Oct 04, 2009 | Lexmark X7170 All-In-One InkJet Printer
HP Photosmart C3180 Printer keeps saying check printer cartaridge I have new ink cartiridges
If you have just replaced them make sure you have pealed off the protective film from the contacts on the cartridges, also make sure you run the wizard for replacing them so that it realigns the printer heads and then it might recognize that they are new.
Sep 12, 2009 | HP Photosmart D5360 InkJet Printer
How do I get my deskjet F4283 to accept a refilled cartridge?
You just need to re-install the cartridge as if it was a new one.
The printer should treat it as if it was a new cartiridge and reset ink levels in the system.
Aug 02, 2009 | HP DeskJet F4280 All In One Printer InkJet
I am getting a message that the print cartridge cradle is stuck. Where is the the cartiridge and how do i unstick it?
On HP's site at THIS LINK I found an article titled: "Resolving 'Print Cartridge is Stuck' Error Message". I hope this helps you. If you need any further help let me know.
Apr 09, 2009 | HP - HP Photosmart 8250 printer
Photo 926 cartridges got stuck and now won't move
Power down printer. Lift cover and manually slide cartiridges left to right a few times. close cover, power on and see if when you open the cover again the cartiridges align. To double check your system is working, try to make a copy of a document.
Mar 23, 2009 | Dell 962 Photo All-In-One InkJet Printer
Standard steps for printer troubleshooting
I have a HP 5940 printer. I just bought a new cartridge HP98 black and my printer states that there is a cartiridge problem? I checked the box and it states that this cartridge is compatible with the printer. Please help!!
Aaliyah
Jun 19, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Printer cartridge cradle is stuck-hp photosmart 7350
I just had the same problem...and this is what I did to get it working...
Turn off your printer. Open the top. Push the cartridge thingie off to the side (if possible) and then take QTips and cleaned the silver bar the cartridge moves on. Got a lot of ink off of it.
Should run after that.
Dec 01, 2007 | HP PhotoSmart 7350 InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
