Question about Dell Dimension 4500 PC Desktop
Usb My usb wont accept a new flash drive it says there is still hardware installed waiting to be removed. There is nothing in the usb port. I, ve disabled and shut down seveal times comes back to the same, waiting for me to remove a hardware device from the drive when there is nothing to remove.
Still not fixed I've been running the flash drive through the printer usb port on the back side of tower.
Posted on Jan 01, 2008
    Sergeant:
  • 239 Answers
Go into your device manager and see if you see any yellow question marks by any usb devices on your pc if there is make sure your online and try an update see if that works first. Also how are you shutting down? are you using the remove hardware Icon on the bottom right? You could also try the Add and Remove hardware in your control panel, Let me know if that works if not write back here.
Posted on Dec 24, 2007
  • bear001 Dec 31, 2007
    Well what did you do to fix your problem ? I would like to know, seems my solution didn't fix your situation. I am one of the only ones out here that does this for NO MONEY. I like doing it but some people I would rather say nothing instead of saying thanks for trying, Let me know what you did to fix your prob. so next time I run into a situation like that I can help.
    Those thanks to trying bring down my % I am only trying to help people I don't want money its just fun Helping others.....
New SanDisk 16GB Cruzer not being recognized by computer
Check ur usb port with other devices.It they were not working properly,
ur usb port is damaged,then put ur device to another usb port.if is not working properly then,ur device is damaged,u can do nothing.
Jun 16, 2012 | SanDisk Cruzer Sdcz36-016g-b35 16 Gb Flash...
How to install a USB flash drive
Just plug your USB flash drive into the USB port of your computer or other USB-equipped device and drag the files you want to take with you into the folder that appears on your screen. Your files are instantly transferred to your USB flash drive. To transfer the items on your USB flash drive onto another computer, simply plug your USB flash drive into the computer that you want the files transferred to, open the folder that appears on your screen, and drag the desired files onto the computer's desktop.
1.) Insert Flash Drive into the USB Port of your computer.
-Where is my USB port? It is usually found in newer model computers in a hidden compartment on the front of the hard drive and in the back of the hard drive on older computers. The port for laptops is found on the side or back of the computer.
2.) Wait for the hardware to automatically install on your computer.
After the hardware is installed, it is ready to use!
3.) In most cases, an Options Window will automatically open. Select "Open folder to view files" Click "OK."
Jul 19, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My Kingston usb flashdrive 16 Gb files was corrupted and so with the installer. Everytime when I insert it shows unknown driver and it's not working. Can you provide us the the installer with this...
You do not need drivers for flash drives. The problem may be your USB ports.
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
If it turns out that the files are indeed corrupted, there are several free recovery programs you can try.
http://www.easeus.com/resource/drive/usb-flash-drive.htm
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 21, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have a problem with my 16GB Kingston DT101G2 flash drive. I accidentally deleted all the installed files in the flash drive the first time I connected it to my PC, and now my PC can't recognize the...
NO...
Flash drives are just like any drive....nothing specific....you cant del system files...even if you format the pen drive the system files are there....
you pc is behaving funny as the USB port is having trouble / pen drive is not connected properly....as no specific drivers are installed fore the USB ports...it's all Windows drivers that sue the USB ports....
Sol
1 remove the pen drive
2 switch off and switch on the PC
3 reconnect the pen drive
it should work now...
for more PC related issues visit my site
reg
Kris
suresh_krishnan1961@yahoo.com
www.sureshayyar.110mb.com
May 18, 2011 | Office Equipment & Supplies
When i plug in my TRANSCEND 4GB USB DRIVE,i got the connecting tone,connecting msg(found new hardware:mass storage device And finnaly problem occured during hardware installation,your new hardware might...
Hi Friend, As you have mentioned that you got the message after installation that it will not work properly, i would like you to check that since you are connecting the USB 2.0 into your system, i would recommend you to please check if the USB ports of the system are compatible with 2.0 version of USB drives
Dec 08, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to solve usb not reconized error in sony vgn-s36gp?
Hello
Disconnect the flash drive from your computer, then plug it into a different USB port. On occasion some USB ports do not detect inserted equipment (either because the port is damaged or because the flash drive is not supported by the particular connection).
Connect the flash drive after the computer has powered on. If you plug the drive into the computer before starting the system, the computer may not detect the USB device.
Open an Internet browser and navigate to the drive manufacturer's website. Although most USB flash drives are plug-n-play, the computer may not have the appropriate drivers installed, which means you must install the driver before the system can use the flash drive.
Select the "Support" option, then choose "Drivers and Downloads". Click on the model of flash drive you are using, then the operating system. Click on the driver download link and wait for the driver to download to the computer. Double-click the downloaded file to load the installation wizard. Accept the license agreement, then follow the prompts to install the driver. Restart the computer and the system is ready to use the USB flash drive.
Oct 12, 2010 | Sony VAIO VGN-CR220E/P Notebook
My laptop does not see my sandisk when I plugged
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Feb 03, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
When I put my DaneElec 4GB USB Drive into my USB port, nothing happens. We have Vista.
Do other USB devices work when you plug them in the USB port?
If they don't then you have a faulty USB port otherwise the DaneElec is faulty or needs formatting.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 18, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
Don't know how to use this.
Just put the PNY 8GB in USB port and wait for a minute to install the driver automatically. if you get msg "Your Hardware is Successfully installed" then go to the "My computer" >> It will shown as "Removable Drive" now you can use the device.
Jan 03, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Don't know whow to install my new PNY flashdrive 1GB attache'premium USB 2.0 drive
Some questions first. Does your system detect a new hardware? If yes, then do the following. If your flash drive comes with a CD, insert it then try installing( the software needed might be in there).
If your system doesnt detect your flash, then it might be that your usb port has been disabled from the Bios settings. But first check your Device Manager to see if your usb ports are working well ( From Control panel- system-Device Manager). If everything is working properly in the device Manager, then call on a technician to look at the Bios settings so as not to complicate things.
Aug 01, 2008 | Computers & Internet
Dell Dimension 4500 PC Desktop Logo
52 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
