Question about Jenn-Air Kitchen Ranges
Neither oven will heat more than 325 degrees, even on broil
  • lisbil1 Oct 06, 2009
    Can you tell me the part numbe and estimated cost. Where is the "high limit unit located?
    President:
  • 1,723 Answers
This is caused by the thermostat or the thermistor (heat sensor) depending on what model you have. Sometimes the capillary bulb on a thermostat can be cleaned and it will fix the problem. Take a look and see what you have.
Posted on Oct 06, 2009
  • 612 Answers
Please keep in mind that I am attempting to diagnose your appliance without being there and with very little information.
There is a high limit on the unit. You will need to replace it. It's what is keeping it from getting hotter. It should only come into play at 520-550 degrees. When they get weak they will cut power to the elements at a lower temp.
My breville oven now takes 40 min to heat to 325 degrees. Even longer for higher tempos. Is there something I can do to fix this problem? 3 years old. Thanks
Bet that one of your heating elements is open. Identify defective unit and replace.
Check out site for parts and availablity. Search Over 2 1 Million Appliance Parts
Sep 02, 2017 | Ovens
Oven will not pre-heat properly
you might want to check where the thermometer is located on older models it can be knocked out of position perhaps to close to the roof of the oven which gives false heat reading
May 01, 2015 | Kenmore Kitchen Ranges
BOSCH HBL3450UC Single Oven weak/slow pre-heat
I have a Kitchen Aid convection wall oven. It takes 6 - 7 minutes to preheat to 325 degrees. You probably have a bad element. There are 2 elements.
Dec 19, 2012 | Bosch HBL3450UC Single Oven
Hi. I have a Maytag CWE4200ACB wall mount oven that seems to have a circuit board/timer problem. When the oven is turned on and temp set you can hear (at the control panel) one click and the "on"...
Hi.
The clicking noise comes from the control board relays. The board has three relays. One for for bake. One for broil. One for light/fan auxiliary functions.
Try switching on only bake or broil. If one of the two elements (either bake or broil) gets hot, then the problem is either element or timer board. Make sure that the element has continuity at the Ohm meter.
If both bake and broil do not work test first the oven temperature sensor located inside the oven cavity. Make sure that impedance of the sensor at room is about 1.1KOhms . If sensor is open or shorted, replace the sensor. If sensor reading is OK test wiring and elements for continuity and eventually replace the control board if the rest is OK. Even if door switch should not affect regular programs, check the door switch reading impedance or jumping it.To test wiring test continuity of red and black lines. Check black line between power cord and relay board. Test with particular attention the oven temperature sensor, that is a common cause for your symptoms. Here the part:Long Oven Sensor Kit
Here a wiring diagram for your oven.
Here all parts and diagrams.
Regards.
Ginko.
Nov 15, 2011 | Kitchen Ranges
My Kenmore Elite oven will take over an hour to preheat to 350 degrees and never does get done preheating.
There's a few things that can cause this.
1. Check to see if the both that Bake and Broil elements (burners) are heating up. Check the Broil element in Broil mode.
- during pre-heat the Broil element gets cycled on and off for short time durations to speed up the heating. If the Bake element is not working, then the oven will heat, but very slowly and never reach high temperature.
2. If the elements are both working, then it's possible that you have a bad temperature sensor.
- this is a temperature dependent resistance device that should measure 1080 ohms at 70 deg F (room temp).
3. If #1 and #2 are ok, then the problem is with your oven clock/control unit. We rebuild these at fixyourboard.com.
Aug 14, 2010 | Kenmore Ovens
Oven will not maintain tempature with what was programmed
You might try calling Sears, or wherever you purchased the oven. Or even an appliance repairman. It sounds like the oven temp needs to be re-calibrated, or buy a thermostat to put inside the oven and follow the temp it says.
May 31, 2010 | Jenn-Air JES9860 Electric Kitchen Range
My oven is burning my baked goods, but shows the right temp with a thermometer. Do I have to turn the dial to broil and then back to the desired temp? Even if the rack is in the middle, everything burns....
If it is convection bake you have to turn the temp down (25 degrees or so) that is listed in the recipe.
The broil setting is not used to bake because it operates differently from the bake setting. So, don't go to the broil setting at all.
The element for bake is under the floor of the oven. You have not indicated whether it is gas or electric, but both of these can have issues with the burner or element.
If you are baking on the correct setting and the oven is heating from the bottom, not the top, this can be caused by hot spots that are created by elements/burners.
to check, look under the floor of the oven. Turn the bake heat up to high and see if the flame is uneven. For an electric oven, the color of the element should be evenly red, no brown spots.
If you are using an oven thermometer, move the thermometer to the spot in the oven that seems to be burning things the most.
Nov 27, 2009 | Kenmore Ovens
Ovens wont heat to temp
The reason to this problem can be due to the faulty
thermostat.
Sep 02, 2009 | Lincoln Conveyor Oven - 1133-000-A
Tappan Oven #MEF500PBWD heating unevenly
Perhaps the item you are using to check temperatures is not accurate. I my line of work, I use a digital thermometer which records immediate temperature. Perhaps understanding the process will help you see more accuracy in the way you read the temperature in your oven. Allow me to offer this explanation....First of all, place your thermometer near on the top rack as close to the oven temperature probe as possible. This probe is the focal point for your oven and detects the temperature and opens the electrical circuit to turn off the element when the desired set temperature is attained. Set your electric oven to 300 degrees and hopefully, you have a window in your oven to watch. The bake element will come on and the temperature will rise until it reaches 300 degrees. It is at this point when your oven bake indicator light should go out. When this happens....look inside. The element is still bright orange and emitting heat and will continue to raise the temperature in the oven to approximately 325 - 340 degrees. With this noted, you will see the temperature beginning to drop 315, 310, 300, 295, 290, 285 perhaps even 280 or some even lower to 275 and then the indicator lamp will go on indicating the circuit has closed thus turning on the element, Finally there is a variance and no range GAS or ELECTRIC will ever maintain a even 300 degree temperature. The calibration set point is based on the 300 degrees. If your oven light goes off within 20-25 degrees of three hundred degrees, your oven is already calibrated pretty close and I would not attempt to adjust it at all.
Feb 16, 2009 | Tappan TEF242 Electric Kitchen Range
Oven slow to heat
In alot of ovens preheat will cause the both the broil and bake element to come on. You are most likely getting heat from the broil element. This means either the bake element is bad or the relay on the oven control is bad. If the element shows resistance with an ohm meter then replace the oven control board.
Sep 30, 2007 | Thermador REF30 Electric Kitchen Range
Kitchen Ranges Logo
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
