Question about HP Photosmart C6180 All-In-One InkJet Printer
Error 0xc19a0035, printer seems to be stuck in shut down mode now. We were out of yellow ink, I have been trying to print in b/w but just kept giving me the above error message, I have replaced the yellow now, and after this error message it said to shut down the printer, which I did and it has been in the shut down mode for well over 5 minutes.
  • 4,041 Answers
Hello there is this link you can try
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 13, 2010
How to Fix HP Printer Error Message 0xc19a0035?
Hi hptechnicalsupportnumber , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Which model printer do you have?
Did you recently change ink cartridges?
Did you perform other cleaning or maintenance?
Is the printer old, or possibly new enough to still be under warranty for free repair?
Examples of web pages with information on fixing this error:
https://h30434.www3.hp.com/t5/Inkjet-Printing/Officejet-7612-Printer-Failure-0xc19a0035/td-p/6417241
https://support.hp.com/us-en/product/hp-officejet-7510-wide-format-all-in-one-printer-series/7127198/model/7127199/document/c00489814
http://www.en.rellenadodecartuchos.com/2015/07/how-to-solve-0xc19a0035-error-problem-of-printer-or-ink-system.html
Jan 30, 2018 | HP Office Equipment & Supplies
My lexmark x3470 wont recognise compatible ink Cartridges any know of a way round this
If the ink cartridges you purchased are not Lexmark - that could be the problem. I used to have a Lexmark printer and I did the same thing - I purchased ink cartridges that were compatible but not Lexmark brand. Everything seemed fine until I tried to print and then I would get the same error sign and low ink message and it would not print. I kept thinking I was doing something else wrong and tried everything. In the end I broke down and got ink cartridges from Lexmark and that solved the problem. Now I have a Brother printer and I never buy anything other than Brother ink cartridges because I'm always afraid of that same thing happening again. I wish I knew which printers WOULD accept those non name brand ink cartridges, but thus far I do not know of any printers that do. Hope this helps you.
Mar 24, 2012 | Lexmark X3470 All-In-One InkJet Printer
The yellow ink cartridge continues to not be recognized by my epson r1900 printer. I've tried numerous times to reset the cartridge and even tried a completely separate new yellow cartridge and the...
This might sound crazy but try this.
Switch the yellow and the magento cartridges out and try to print, it will error out again. Then switch them back to the proper slot. Try this first and it should work, if not, please reply back to me.
Jun 12, 2011 | Office Equipment & Supplies
I am getting an error 0xc19a0035 that says: Ink System has Failed. unable to print. Refer to printer documentation. Any help with this issue?
I have had a similar problem when one of my ink cartridges was faulty. Have you check them and/or tried to replace one?
Mar 28, 2011 | HP Photosmart C7180 All-In-One InkJet...
Error 0xc19a0035
Hi Good day!!!
Most likely this is a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer and wait for the carriage to slide over. If for some reason it does not follow these instructions:
(a) Unplug the printer
(b) Manually slide the carriage over until you can get the ink cartridges out.
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
Thank you for using FixYa
don't forget to vote thanks!!
Nov 14, 2010 | HP Photosmart C7280 Laser Printer
I have an Hp c5180 and I am unable to print.
Look here: http://www.out-of-warranty.com/ink-system-failure-error-0xc18a-hp
Oct 04, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error 09,036.44:41689
09,03x 35 = Cyan 36 = Magenta 37 = Yellow 38 = Black The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
May 01, 2009 | Xerox Phaser 8560MFP Laser Printer
Magenta Ink cartridge is stuck in Xerox Phaser 8550/8560
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
Scroll down to the function menu, hit ok, scoll to clear isc fault, hit ok.
Mar 31, 2009 | Xerox Phaser 8560MFP Laser Printer
Error ##343 and it didn't print anything Orange light below screen has been flashing, screen message "Waste Ink Nearly Full". No idea where waste ink container is kept? Have changed cartridges. Now saying...
Manual Reset procedure Waste Ink Tank for Canon MP390:
  1. Start with printer on, press additional functions, Scan, Copy, Scan. Now you should be in service mode.
  2. Select Test mode (must be the last available selection).
  3. Select #8 Printer Test, it will start cleaning then it will come up with some other option: push the + or - button until it says 8-3 then hit the select button
  4. The menu will now say EEPROM Clear
  5. Select Ink count which is option (0) and press set
  6. Press Stop/Reset Followed by the power button and then wait for it to restart.
hope it helps
cheers
Jun 09, 2008 | Canon SmartBase MP390 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
420 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
