NO PICTURE AFTER FEW MINUTES/DARK PICTURE/ERRATIC/NO MENU VISSIBLE
I RECEIVED ASSISTANCE AND WAS TOLD THE FOLLOWING-
If everything else works - there is sound and high voltage (static on the screen) - but there is no picture (including no on-screen menus), this limits the likely area of problems is the video output circuitry or CRT filament connections. Check to see if the CRT filaments are glowing. If they are not glowing, check for bad soldering on the CRT neck board and around the flyback transformer.
Where the picture is erratic - coming and going entirely or changing brightness suddenly, with power off, remove the picture tube socket (carefully!) and clean the pins with fine sandpaper and use contact cleaner on the socket. This source of bad connections can result in a variety of erratic symptoms. Check for bad solder connections on the CRT neck board.
MY QUESTION NOW IS WHERE IS CRT FILAMENT CONNECTIONS & THE PICTURE TUBE SOCKET?
MODEL NO. A56M91W5
SERIAL 881-1350-1160
  • 8,617 Answers
Most projections have a removable speaker cover on the front under the screen. Then there is an access panel that you remove the CRT sockets are the circuit boards attached to the CRTs
Posted on Jan 22, 2008
Samsung LE32R738D 32 inch LCD television has stopped diplaying a picture
ou just need to replace the inverter board. Very es=asy and takes just a few minutes with a screwdriver.. no special tools required. You can get the inverter board from www.tvrepairworld.com and they can assist with installation assistance if needed.
Jan 10, 2013 | Televison & Video
No luminance
poor very dark is sighn of bad bulb ok after 3000 hours they get dark they wont die just get darker in darker like what going on now and have stuff looks like red nasty get new bulb ok
Feb 10, 2008 | Mitsubishi WD62627 62" HDTV
JVC TV THE PICTURE IS DARK EVERYTHING ELSE WORKS GREAT
there so many things which can cause that to happen an these are thwe following,
i a tube has to be tested
ii a line transformer
iii vedio amplifier
this tests can be done in w/shop where other tvs are of the same.
Mar 27, 2009 | Televison & Video
Dark background blue tint
Try the Magic Focus option on the menu screen found under "Picture". Make sure the TV is on for 20 minutes before activating this option. It is also best to run this when the room is dark.
Jan 19, 2009 | Hitachi 57F500 57" Rear Projection...
Screen bounces, picture bows, screen floats up.
your STK 392-110 IC's are bad replace and it will be fine. these chips go bad and its like changing tires on a car you have to do it now and then.
Dec 21, 2008 | Sony KP-61HS10 61" Rear Projection...
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Hitachi 53UDX10B 53 in
the picture turns blue because the blue crt stop working you 'll need a tech
Aug 02, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Picture is very dark will not brighten
We changed the lamp too.Picture is very good now. There isn't a way to test lamp because it is filled with gas.when changing lamp make sure you put everything back on covers etc. before checking to see if it works.
Jul 26, 2008 | RCA HD50LPW42 50" Rear Projection HDTV
Picture Fades
The more you play set the longer it will last, it sounds like you may have poor connections, cold solder joints try soldering around flyback transformer.
Apr 03, 2008 | Zenith R56W36 56" Rear Projection...
Dark Picture to no picture
Probably has some bad solder connections in the deflection/ power supply area, if you dont know about electronics, might call a repairman and put a few hundred $ into it or junk it, also it is not HD, just FYI
Jul 07, 2007 | Mitsubishi VS-5059 50" Rear Projection...
Televison & Video Logo
202 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
