We have a rolling picture as if something is loose. It straightens out after a couple of bangs,
    Scholar:
  • 102 Answers
If the set does not have a "horizontal hold" feature, and few do these days, DO NOT bang on the set. Projection TVs may have high voltages inside. If one thing has come loose, banging can only loosen other things.
It may be as simple as a loose connector but ONLY a qualified TV/Computer peripheral technician can do it safely.
Posted on Oct 06, 2009
Riccar supralite makes a loud rattling noise like the roller is banging around
If the noise is not something in the brush roll or the brush roll bearings or shaft is damaged the impeller may have something stuck in it or it may be broken.
May 15, 2014 | Riccar Vacuums
Riso 370 d-17
D-17 indicates incorrect master roll. there's several possibilites for this. the mosty common are:
1. its an incorrect master roll
2. (common) if you look at the back of the drum there's a black coupling jack. check the silver pins. sometimes the pins come undone and push back from making contact. (sometimes not straightenable and must be replaced)
3. (less common) Same issue as above, pins are pushed back on black jack behind master making unit inside of riso. (sometimes not straightenable and must be replaced)
4. (rarely) antenna is loose either inside of drum or from antenna pcb in lower right corner, behind front cover of master making unit.
5. (even more rare) bad rf reader, antenna, cable (usually visably pinched) or antenna pcb
Mar 06, 2014 | Riso RZ220 Duplicator
I purchased a Commercial Cool Haier portable rolling air conditioner CPN11XCJ from QVC and the compressor noise is aweful. I was told this was a shipping damage issue. The unit works fine but the noise....
Check the compressor. It probably fell out of it's mounting bracket during shipping. Maybe turned upside down or something. Make sure the compressor is sitting solid and it's rubber feet are in place. If you continue to use this unit with a loose compressor, you may damage or break a refrigerant line.
Jul 08, 2010 | Haier Heating & Cooling
My Maytag Ensignia washer is not spinning well. It bangs side to side with even the smallest loads. It seems like something is loose. Is this something I can fix myself or do I need a repair mans help....
Try leveling the washer... If the washer is level, then don't wrap the clothes around the agitator...drop the clothes straight in, on top of each other evenly around the agitator. The Ensignia washer has a Dual action agitator... That means the clothes roll over them selves, instead of moving side to side, as with a traditional agitator. wrapping the clothes around the agitator will cause the load to be un balanced and then cause the "banging" noise... this should take care of the problem...
Jul 31, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
Washer won't spin makes banging sound
remove the agitator. there is a cone shaped block on the agitator shaft and locked to the tub via a large lock nut. spin tube has 2 tabs that lock into slots on top of block. these can strip out and cause the spin tube to spin inside block. watch it and turn machine on spin. tub can also drop and drag on bottom of outer tub. if this is it replace block and gently straighten tabs on spin tube.
Jun 11, 2009 | Whirlpool Washing Machines
ROLLING PICTURE HATACHI
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Compressor bangs
If you take the back off you will proably see that the feet are bent. Try to straighten out as much of the metal as you can. The compressor is a motor that sits on springs to keep it quiet. If you get the compressor to sit level the banging should stop.
Dec 16, 2008 | Kenmore Refrigerators
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
