Question about Philips VOX120 Wireless Headset
Philips SHB6100 headset with bluetooth
Hi if bought this headset a wile ago and i lost my instalation cd is there anny 1 who know were i can fint the software? i tried a lot and also with bleutooth its connecting but still plays the music over my speakers and not my headset ? anny help would be great >
3 Suggested Answers
SOURCE: Pin number for philips SHB6100 aside from 0000.
yeah hedenram is right. my problem was that i was trying to pair something WITHOUT the headset in pairing mode. just switching it on doesnt put the headset in pairing mode and it will reject the 0000 passkey even if this is correct. it is vital when you turn on you hold the power button til it flashes red/green and then it will be in pairing mode and accept the 0000. the only way i found this was in the instruction booklet which i thought i had chucked away
Posted on Nov 27, 2008
rockfixya
  • 679 Answers
SOURCE: Connection problem for Philips VOX130 with other bluetooth devices
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select VOX130 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Posted on Jan 31, 2009
I can't connect my Iphone 5 to my bluetooth headset.
Did you put the bluetooth device in pairing mode? That way it is discoverable. Go to the bluetooth screen on the iPhone. Do you see the device listed there?
Jan 19, 2013 | Apple iPhone Cell Phones
How to pair philips shb6100 with ipad2
First, in order to pair the iPad to a Bluetooth device you need to make sure the Bluetooth device is discoverable. Refer to the instruction manual for the device (which you can find online usually if you lost it) on how to do this. Typically, it just involves holding down a button for a few seconds. Next, you need to turn the iPad's Bluetooth capability on. Go to Settings by touching the Settings App icon that looks like gears. Within Settings, select General and then Bluetooth. Once you are in the Bluetooth screen, press the on/off switch to turn Bluetooth on. Make sure it reads "on". Once you turn on Bluetooth, you should see the discoverable Bluetooth device show up on the screen as part of a list. Select the device you wish to pair with the iPad. Depending on the device, it may prompt you for a password. Refer to the Bluetooth device's product manual for this password. Hope this helps
May 18, 2011 | Philips Televison & Video
CAN'T GETHE HEAD SET CONNECTED TO MY RAZOR
Hey Sadie,
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Explorer 3XX device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya
Chris (ziraffa)
Dec 19, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth headset won't connect in Vista
I had a similar problem. First part of the solution is to disable the headset profile for the headphones. These headphones can't handle both headset and headphone profiles at the same time. Second part of the solution is to make sure that your headphones are on when you activate bluetooth on the computer. For some reason, Vista doesn't like setting up the initial connection on-the-go, so it will just act like its connected and move on. Hope this helps!
Dec 07, 2008 | Insignia Bluetooth Wireless...
Oct 22, 2008 | Philips VOX120 Wireless Headset
Tips:
Jul 05, 2008 | Philips VOX130 Wireless Headset
Bought a Jabra BT135 and lost instructions to install, please help
1. ok when the headset is off keep your finger on the botton until it goes blue (stays blue)
2.when gone solid blue search on your phone for bluetooth
devices and you should find it
3. then it askes for the pairing key type in 0000
4.when you play music while bluetooth hedset is on and bluetooth is on it should play in the headset
Jan 22, 2008 | Cell Phones
Philips VOX120 Wireless Headset Logo
98 people viewed this question
Top Philips Radio Communications Experts
Computer Repairing
Computer Repairing
Dayton Computer
Dayton Computer
kiranbodapothula
Are you a Philips Radio Communication Expert? Answer questions, earn points and help others
